Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Other Sciences > Chemistry
Reply
image How to distinguish Isopropanol? Share It Thread Tools Search this Thread image
Old Nov28-09, 04:13 PM                  #1
Si14
Si14 is Offline:
Hello:
I have a liquid in a bottle. I want to know whether it is Isopropanol or not. I want to distinguish it among Methanol, Acetone and Ethelin.
Can you help?
Thanks.
Old Nov28-09, 11:10 PM                  #2
pzona
pzona is Offline:
Re: How to distinguish Isopropanol?
There are a ton of methods for this, but some are easier and more practical. What kind of lab equipment do you have available, if any?
Old Nov28-09, 11:30 PM                  #3
Si14
Si14 is Offline:
Thanks.
I have those materials, and about stuffs, we've got Ni gas, ultrasonic bath and other ordinary equipments that can be found in any lab.
Old Nov29-09, 01:51 AM                  #4
pzona
pzona is Offline:
I'm sure the best way would be to use spectroscopy (NMR, IR, etc.), but I don't know what type of lab you're in. Those machines can be found at most universities, which, if I had to guess, is the type of lab you mean.
I'm not sure what to do with Ni gas or an ultrasonic bath, as I've only had one semester of chem lab so far, not counting high school. I can't really give any specific methods (besides spectroscopy) for identifying your solvents, but I know someone else here can probably suggest something.
Old Nov29-09, 02:07 AM                  #5
chemisttree
chemisttree's Avatar
chemisttree is Offline:
Recognitions:
Homework Helper Homework Helper
Methanol isn't soluble in hexanes. Acetone will test positive for a methyl ketone(google "iodoform test"). BP of ethanol and acetone are pretty different from each other and from IPA. Any help?
Old Nov29-09, 04:28 AM                  #6
Si14
Si14 is Offline:
Thanks a lot!
Just to clear something: I know nothing about chemistry! I just wanted to know is there any "simple" way to distinguish Isopropanol from Acetone and Methane and Ethelin?
I used it for cleaning something.
Thanks again.
Old Nov29-09, 10:54 AM                  #7
sjb-2812
sjb-2812 is Offline:
Just to confirm, is it methane, or methanol that is one of the unknowns you want to eliminate? And what is "Ethelin"? ethylene (ethene) ?
Old Nov29-09, 11:09 AM                  #8
Si14
Si14 is Offline:
Thanks again.
OK, we have four materials:
Isopropanol, Acetone, Methanol, Ethylene.
All of them are colorless, so I can't distinguish them by color.
I can somehow distinguish by smelling them.
But I want to know whether is there any other way to distinguish the Isopropanol among these materials?
So, I am interested in distinguishing Isopropanol.
Thanks alot.
Old Nov29-09, 01:37 PM                  #9
sjb-2812
Well, at room temperature and pressure, ethylene is a gas, so that's easily identified. Acetone will have a characteristic IR stretch for the carbonyl, and methanol and IPA have a difference of around 20 degrees C for boiling point, so that's enough of a difference to separate them if you're careful.
Old Nov29-09, 02:19 PM                  #10
Si14
Si14 is Offline:
Thank you very much.
Originally Posted by sjb-2812 View Post
ethylene is a gas
I think I gave you a wrong name. Since it is a liquid, so I think it is Ethanol.
Acetone will have a characteristic IR stretch for the carbonyl.
What is this IR stretch? (as I said, I am not familiar with chemistry and I am using this IPA for cleaning only)
Great! So far, I can distinguish methanol and IPA? BTW, can I simply pour some of these two liquids in separate beakers and then warm them up to boil? and I will notice which one boils first. Is this correct?
Thanks a lot again.
Old Nov29-09, 05:35 PM                  #11
pzona
pzona is Offline:
Considering you know very little about chemistry, boiling point might be the easiest way to distinguish between them. Like chemisttree said, the boiling points are pretty far apart, so you just need a thermometer and a hot plate (and eyes of course) to get a general idea of which is which.
Old Nov29-09, 10:59 PM                  #12
gravenewworld
gravenewworld is Offline:
NMR all these other techniques are outdated. You don't even need to know anything about NMR, just take one and match it to a reference. NMR will tell you EXACTLY what you have.
Old Nov30-09, 12:32 AM                  #13
pzona
pzona is Offline:
Very true, NMR is probably the best way to identify any organic compound. For the OP's purpose though, I think boiling point will suffice.
Old Nov30-09, 03:51 AM                  #14
Borek
Borek's Avatar
Other Sci 2009
Borek is Online:
Recognitions:
PF Contributor PF Contributor
Overkill. NMR is expensive when compared with other techniques proposed and is not easily available in every place.
When my car has small scratch I am not thinking about building a robotic paint shop, I am rather looking for a small brush and a can of paint.
ChemBuddy chemical calculators - buffer calculator, stoichiometry calculator
www.ph-meter.info - ph meter, ph electrode
Old Nov30-09, 01:33 PM                  #15
chemisttree
Recognitions:
Thanks again.
OH! In that case do the following:
1. Try to clean with your unknown.
2. Examine the result. If it cleans it, get on with your life.
3. If not clean, choose another solvent and GOTO 1....
Old Dec3-09, 07:04 PM                  #16
Si14
Si14 is Offline:
Good hints!
Thanks all.
image image
Reply
Thread Tools
Similar Threads for: How to distinguish Isopropanol?
Thread Thread Starter Forum Replies Last Post
How to distinguish different phonon branches? qiub Atomic, Solid State, Comp. Physics 2 Jul10-09 11:21 AM
Distinguish between polyunsaturated vegetable oil and petroleum oil xiaofupo Other Sciences 2 Jan14-09 04:33 AM
How to distinguish between pairs of componds? xiaofupo Other Sciences 2 Jan11-09 03:24 PM
How to distinguish linkage and crossover? maxpayne_lhp Biology 1 Mar29-05 07:32 AM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
