Projectile Problem No air resistance(At what velocity was object thrown?)
The problem involves an object thrown into the air at an angle of 35 degrees with a total air time of 9.26 seconds. Participants are exploring how to determine the initial velocity of the object based on its motion under the influence of gravity, without air resistance.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss using kinematic equations to analyze vertical motion and question the validity of calculated vertical displacement. There is also exploration of how to derive the initial velocity from vertical and horizontal components, as well as the implications of the object's return to the ground level.
The discussion is active, with participants providing guidance on using specific equations for vertical motion and engaging in dialogue about the implications of vertical displacement. Multiple interpretations of the problem are being explored, particularly regarding the initial velocity and the relationship between vertical and horizontal components.
There is uncertainty regarding the vertical displacement value and its role in calculating the initial velocity. Participants are also considering the implications of the object starting and ending at the same height, which affects the analysis.
1irishman
An object is thrown into the air from the ground at an angle of 35deg to the horizontal. If this object is in the air for 9.26 s, at what velocity was it thrown?
vf^2=vi^2+2ad
d=vit +1/2at^2
d=v/t
a=vf-vi/t
x motion
vi=vf because no acceleration
t=9.26 s
a=0
y motion
a= -9.8
t=9.26
d=419.7m
vf=90.7m/s
vi=0
I arrived at vertical distance by the following:
90.7^2 = 0 + 2(-9.8)d
d=419.7
I arrived at final vertical velocity by the following:
-9.8=vf-0/9.26
vf=90.7m/s
I don't know if these are correct values or not, but even if they are...i don't know how they arrived at the final answer of 79.1m/s. Please help?
1irishman said:
d=vit +1/2at^2
This is the equation you want to use to analyze the vertical motion. Use this to solve for vi, which will be the vertical component of the initial velocity. (Then use some trig to find the total velocity, given that component.)
don't we have to know the value for d first though before we can solve for vi on the vertical? Is my value of d wrong above?
Presumably it starts and ends on the ground, so what is d (vertical position) after 9.26 s?
What's "d" (vertical displacement) if the object goes up and comes down to the same height?
zero?
so vi on vertical is 45.4m/s?
I have horizontal Rx=45.4/sin35=79.1, so the object was thrown initially at 79.1m/s right?
Yeah. You could have gotten this by noting that gravity decelerates objects at 9.8 m/s every second and that the ball took 9.26/2 s to reach maximum height, so the object was initially moving at 9.8*9.26/2 m/s.
yeah, but that would be too easy! Just kidding, thank you.
If i had used max height for this problem, could I have solved for vi then as well?
  • · Replies 34 ·
