Local max and min at a if lim f(x) approaching a does not exist
  • Context: Undergrad
  • Thread starter Thread starter merry
    Local Max
The discussion centers on the existence of local maxima and minima at endpoints of a function defined over a finite interval. It is established that local extrema can indeed exist at endpoints, contrary to the high school perspective that requires the function to be defined on both sides of the point. The conversation highlights the pedagogical preference for considering only interior points, but acknowledges that endpoints can serve as local extrema unless the function is constant near those points. This clarification resolves the conflicting views presented by different educators.
  • Understanding of local maxima and minima in calculus
  • Familiarity with the concept of finite intervals in function analysis
  • Basic knowledge of function continuity and behavior near endpoints
  • Awareness of pedagogical approaches to teaching calculus concepts
  • Research the definition and properties of local extrema in calculus
  • Study the implications of function continuity at endpoints
  • Examine different pedagogical approaches to teaching calculus concepts
  • Explore examples of functions with local extrema at endpoints
Students of calculus, educators teaching mathematical concepts, and anyone interested in the nuances of function behavior at endpoints.
merry
Hi,
I understand that the local max of a function is the point at which the y value of the function is larger than the neighbouring y values of the function.
Say we're considering the local max at a of a function f(x). Does the function have to exist on both sides of a for (a,f(a)) to be a local max? (consider the same situation for a local min).
In short, if the fuction exists at [a, b] [tex]\epsilon[/tex][tex]\Re[/tex] only,
can there be a local max or min at (a, f(a)) or (b, f(b)) ?
My high school professor said that to have local extrema, the function should exist on either side of the point. However, I believe my University prof said that this is not the case.
Could someone please clarify as to which one is the case?
Thanks a ton!
Merry
It appears to be a quibble over definition. If you have a function defined over a finite interval, the end point values will almost always be local extrema (unless the function is constant near the end point). For pedogogical reasons, it is better to consider only interior points.
Thanks! =D
I asked my Uni prof and he said that our high school textbooks are wrong and that local extrema can exist at end points xD
Thanks for the answer though!
