Question about Entanglement and electron spin
The discussion revolves around the concept of quantum entanglement, specifically focusing on electron spin. Participants explore the implications of entangling multiple electrons, the nature of spin states in entangled systems, and the relationship between entanglement and the Pauli exclusion principle. The scope includes theoretical considerations and conceptual clarifications rather than specific problems or applications.
  • One participant questions what happens when three electrons are entangled, noting that there cannot be just one up-spin and one down-spin in such a case.
  • Another participant mentions conservation of spin and the Heisenberg Uncertainty Principle, suggesting that the total spin of three entangled electrons could be +1/2 or -1/2, but is uncertain about the possibility of +3/2 or -3/2 states.
  • A participant raises concerns about entangling two electrons with the same spin, questioning how this can occur if there is no determinant for which electron changes spin.
  • Clarifications are made regarding the distinction between the Pauli exclusion principle and entanglement, with one participant stating that entanglement does not restrict the spins of entangled particles.
  • Some participants express that entangled electrons can have the same spin states, challenging the notion that entanglement requires opposite spins.
  • There is a discussion about whether two entangled electrons necessarily have opposite spins, with some asserting that this is typically the case, while others suggest that this may not hold for systems with more than two electrons.
  • A participant inquires about the feasibility of entangling two electrons that initially have the same spin and whether the outcome is random.
Participants express differing views on whether entangled electrons must have opposite spins, with some asserting this is a requirement while others argue it is not. The discussion remains unresolved regarding the specifics of entangling electrons with the same spin and the implications of entangling multiple electrons.
There are limitations in the discussion regarding assumptions about spin states, the definitions of entanglement, and the implications of the Pauli exclusion principle. Participants do not reach a consensus on the nature of entangled states involving multiple electrons.
QuantumVegan
I'm working on a research paper on Quantum Entanglement and came across something I don't understand. (I assume this goes here rather than in the homework forum because it applies to a topic rather than a problem. Sorry if I'm mistaken.) From what I've read, if two electrons are entangled, one will have an up-spin and the other will have a down-spin. However, there can be more than two electrons entangled (scientists have entangled three). With three electrons, there can't be just one with up-spin and one with down-spin, so what happens?
Secondly, what happens if two electrons with the same spin are entangled? For example, two electrons, each with up-spin, are entangled--one should stay up-spin and one should switch to down-spin, correct? Yet if they are entangled and have negligible differences, there is nothing to determine which one switches to down-spin and which one remains up-spin. How does this work?
Sorry if these are stupid questions, I am in 11th grade in high school so I have not yet had any quantum mechanics courses.
Any help is appreciated. Thanks.
Welcome to PhysicsForums, QuantumVegan!
The actual underlying rules are a) that there is conservation of spin; and b) the Heisenberg Uncertainty Principle applies - preventing you from knowing non-commuting spin components. An electron has 3 spin components: x, y and z (corresponding to 3D). None of these commute, so knowledge of Y means X and Z are completely uncertain.
If there are 3 entangled electrons (by convention electron spin is either +1/2 or -1/2), then spin will not total 0 as you say. It will be +1/2 or -1/2. I am not sure if the +3/2 or -3/2 entangled states are possible, I would guess so.
Thanks for the help! Yet I'm still wondering about one thing. Can two electrons with the same spin components be entangled, seeing as there is nothing to determine which one changes spin? Does this go by the assumption that the spin components do not exist until observed?
One other thing: It is required that the total of all spin components (x1+y1+z1+x2+y2+z2, with 1 and 2 denoting separate electrons) have a sum of 0, correct? How I understand it is then adding a third electron (or having any odd number of electrons) will violate this rule?
Thanks.
It seems that you are confusing two different things - Pauli exclusion principle and entanglement.
For electrons in a single atom, Pauli exclusion principle states that no two electrons can have the same quantum numbers.
Entanglement describes situation when describing two (or more) distant particles with single wavefunction gives you additional information about particles. Entanglement itself does not restrict how particles are entangled - with the same spin superposition or opposite.
Because of Pauli exclusion principle it might be hard to come up with mechanism for source producing three entangled electrons but that is not restriction of entanglement.
Sorry for the late response, I was busy with school and forgot about this.
I know what exclusion is; I read that entanglement requires opposite spins, but maybe what I read was mistaken. How I understand it now, two entangled electrons can each have +1/2, each have -1/2, or one of each, i.e., there is no restriction? Thanks.
There are a number of ways to have entanglement, electrons with opposite spins are just one example. You can have photons, ions, etc. as well as partial entanglement or entanglement of "odd" observables. The point being that you have to look at specific situations.
So you are asking about 2 electrons, but it seems that you might have another underlying question. If so, you could share that and maybe learn a little more.
I know various things can be entangled; my question is specifically about electrons. Right now I am wondering: If exactly two electrons are entangled, do they necessarily have opposite spins?
As far as I know, 2 entangled electrons always have opposite spins as you suggest. However, there are cases in which 3 or more electrons can be entangled and such will not always be the case. Of course, we are moving into some exotic setups in these cases. See for example:
http://arxiv.org/abs/cond-mat/0406672
Okay, thanks. Does that mean that it is impossible for a human to entangle exactly two electrons which initially (before entanglement) have the same spin?
If it is possible, is it random which electron will switch spin?
  • · Replies 19 ·
