Calculating Tension and Total Force in Equilibrium Torque System
The discussion focuses on calculating the tension in a wire and the total force at the hinge for a uniform beam in equilibrium. The beam is 5.00 m long with a mass of 2000 kg. The tension in the wire was calculated using torque equations, resulting in a tension of 26926.87 N. The calculations involved the gravitational force acting on the beam and the angle of the wire, specifically using the formula T*sinθ*L for torque due to tension.
  • Understanding of torque and equilibrium in physics
  • Familiarity with trigonometric functions in relation to angles
  • Knowledge of force calculations involving mass and gravity
  • Basic principles of static systems and forces
  • Study the principles of static equilibrium in physics
  • Learn about torque calculations in different contexts
  • Explore the role of angles in force and tension calculations
  • Investigate real-world applications of tension in structural engineering
Students studying physics, engineers involved in structural design, and anyone interested in the mechanics of forces and torques in equilibrium systems.
joemama69
Note Picture...
A uniform beam, 5.00 m long with a mass of 2.00 x 103 kg, is held against a wall in the position shown by a hinge and a horizontal steel wire attached to its end.
a) Find the tension in the wire.
b) Find the magnitude of the total force supplied by the hinge.
the only forces for the torque is the mass of the beam perpendicular to the beam as well as the tension of the cable
beam torque = mgdcosQ = 2000(9.8)(2.5)(cos20)
tension torque = TxsinQ this is where I am a littel confused because the tension is in the x direction but the torque should be perpindicular to the beam so its confusing me.
2000(9.8)(2.5)(cos20) = TxsinQ...Tx = 135426.28
is this correct
T
  • 2.pdf
    2.pdf
Torque due to the tension is T*sinθ*L where L is the length of the beam.
oh right right...
2000(9.8)(2.5)(cos20) = Tx(5)sin20...Tx = 26926.87 N
is this correct
