| Thread Closed |
Quick way of raising matrices to indicies |
Share Thread |
| Nov30-09, 03:17 PM | #1 |
A given matrix [tex] A(x) =\left | \begin{array}{cc} cos(x)&sin(x)\\ -sin(x)&cos(x) \end{array}\right | [/tex] Find the term in the first row and second column A^{5}(x) when x = 18° 2. Relevant equations 3. The attempt at a solution Instead of multiplying the matrix again and again by itself in a iterative procedure is there any quicker way? Thanks Thomas |
| Nov30-09, 03:21 PM | #2 |
Recognitions:
For this particular matrix, why don't you find A^2 for general x, and use your knowledge of trigonometric identities...then you may see a pattern.
| Nov30-09, 04:00 PM | #3 |
A^2 = [ cos2x 2cosxsinx
-2cosxsinx cos2x ] what I want is cos²x + sin²x so i get one, but what I got at the mooment doesn't seem to get me any where :( I wanted somthing like if the power is odd then you get -1 and even 1 in the first element, but can't see that happening :( |
| Nov30-09, 04:12 PM | #4 |
Since 2 cos x sin x = sin 2x, a pattern is emerging, just not the one you thought.
| Nov30-09, 05:00 PM | #5 |
aha so the formula for that specific elemnt is [tex]\sin 2^{n-1}x[/tex]
Correct? Thanks Tom |
| Nov30-09, 07:34 PM | #6 |
Maybe for [tex]A^{2^{n-1}}[/tex] but that doesn't help with [tex]A^5[/tex].
In other words, multiply [tex]A^2[/tex] by [tex]A[/tex], not by [tex]A^2[/tex], to find [tex]A^3[/tex]. (I know you know this -- your brain just went into overdrive and caused a blunder.) |
| Dec3-09, 02:52 PM | #7 |
ahhh Im getting
A^3 [tex] A(x) =\left | \begin{array}{cc} cos(x)cos(2x)-sin(x)sin(2x)& cos(x)cos(2x) +sin(x)sin(2x)\\ -cos(x)cos(2x)-sin(x)sin(2x)& cos(x)cos(2x)-sin(x)sin(2x) \end{array}\right | [/tex] where is this pattern? I can see they're all similar I might as well just expand to A^5 now :( |
| Dec3-09, 03:07 PM | #8 |
What is the trig identity for cos(A+B)? For sin(A+B)?
Also, your A^3 has two incorrect entries. |
| Dec3-09, 03:59 PM | #9 |
cos(A+B) = cosACosB - sinAsinB
sin(A+B) = sinAcosB + cosAsinB right? I can see how we can use RCos(x+a) for A^3 but I want to get A^5. There must be some relationship! Which of the terms are incorrect in A^3 btw for A^2 i got [cos2x sin2x -sin2x cos2x] Thanks Thomas |
| Dec3-09, 04:17 PM | #10 |
Admin
I am sure BB means something much faster, but whenever I hear about anything raised to large integer power I think in terms of powers of 2, in this case it means A5=A*(A2)2 - that means just three multiplications instead of 5. The larger the exponent, the more you save.
| Dec3-09, 05:08 PM | #11 |
Can't you guess the correct pattern just from this! ![]() Additional hint: A(x) corresponds to rotation through an angle of x. |
| Dec3-09, 05:19 PM | #12 |
I can see A^2 = sin2x
but I cannot see why that is so argghh! must be something really simple!!! |
| Dec3-09, 09:18 PM | #13 |
A=
[cos x sin x -sin x cos x] A^2= [cos 2x sin 2x -sin 2x cos 2x] A^3= what would you guess! Yes, it's very simple, sorry. ![]() Now compute A^3, and if it doesn't match your guess, then your computation is probably wrong, not your guess! |
| Dec4-09, 04:58 AM | #14 |
You might also note that
[tex]\begin{bmatrix}cos(\theta) & sin(\theta) \\ -sin(\theta) & sin(\theta)\end{bmatrix}[/tex] corresponds to a rotation by -x degrees. Multiplying it by itself 5 times is the same as rotating by -5x degrees. In this case that is -5(18)= -90 degrees. The result is suprisingly simple. |
| Dec6-09, 06:11 PM | #15 |
yeah I didn't think of that!
still need to expand it manually to see the maths but bed time now Thanks for the help! Thomas |
| Thread Closed |
Similar discussions for: Quick way of raising matrices to indicies
| Refractive Indicies | General Physics | 3 | ||
| Raising Matrices to power of n. (complex) | Linear & Abstract Algebra | 7 | ||
| Useful Raising/Lowering Operator Equation, Quick derivation help | Advanced Physics Homework | 3 | ||
| Indices proof | General Math | 7 | ||
| quick question with matrices | Introductory Physics Homework | 1 | ||
