| Thread Closed |
Method of Sections |
Share Thread | Thread Tools |
| Nov30-09, 03:26 PM | #1 |
Method of Sections
Is it possible to use method of sections on a frame or only on trusses? I have a frame that opposes a horizontal load and to find the forces in each member, I used method of sections. Is this right or is the only way to solve the forces is by analysis of each member.
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Dec2-09, 08:00 AM | #2 |
When you say frame, do you mean the connection points between each member are fixed in both rotation and translation (e.g. they are moment connections)?
| Dec2-09, 11:01 AM | #3 |
Method of sections only works if your structure is entirely composed of two-force members. This also holds true for the method of joints. If your structure contains moments or the assumption of only two-force members is not valid, then neither method will work and you will need to look at more complex methods (finite element).
| Thread Closed |
| Thread Tools | |
Similar Threads for: Method of Sections
| Truss Analysis and Method of Sections | General Engineering | 12 | ||
| Resolving forces on a hydraulic frame - method of sections? | Engineering, Comp Sci, & Technology Homework | 0 | ||
| How do I know when to use the Mesh Current Method or Node Voltage Method? | Electrical Engineering | 1 | ||
| Help Sections | Forum Feedback & Announcements | 18 | ||
| washer method and disc method for finding volumes of graphs | Calculus | 5 | ||
