How long does a ball with a mass m take to hit the ground?
  • Thread starter Thread starter stephanna
    Ball Ground Mass
The problem involves a rubber ball of mass m dropped from a height of 10 m, with questions regarding the time it takes to hit the ground, its velocity upon impact, and the behavior of the ball during subsequent bounces, including energy loss and height reached after each bounce.
  • Participants discuss the calculations for time and velocity at impact, questioning the validity of certain equations used under conditions of acceleration. There are attempts to derive the time for subsequent bounces and the heights reached after each bounce, with some participants expressing confusion over the decreasing time values.
Some participants have offered guidance on the approach to calculating the time of each bounce and the relationship between potential and kinetic energy. There is acknowledgment of the need to clarify assumptions about constant velocity versus acceleration, and multiple interpretations of the problem are being explored.
Participants note that the ball loses 20% of its energy with each bounce, which affects the height reached after each bounce. There is also mention of potential confusion regarding the equations used for calculating time and velocity in the context of a ball under acceleration due to gravity.
stephanna
At t = 0 a rubber ball of mass m is dropped from a height of 10 m.
(i) When does it reach the ground? How fast is it moving when it hits the ground?
Each time it bounces, the ball looses 20% of its energy.
(ii) Calculate the height it reaches on the 1st bounce, and the time at which it hits the
ground for the second time and for the third time.
(iii) Find a formula for the time of the nth bounce. When does the ball come to rest?
[Hint: Look carefully at the times between bounces. You may use any formulae you know
from basic mechanics. The acceleration due to gravity is g = 9:81 m s^-2.]
K.E. =1/2 * MV^2 Where M=mass V= Verlocity G=Gravity H=HEIGHT T=Time
P.E. =MGH
SO ...GH=1/2 * V^2 ...M is canceled from each side
V=H/T and V=(2*G*H)^-1/2 so both equations equal each other hence
T=H/(2*G*H)^-1/2
H=(1/2 * V^2)/G
PART i)
GH=1/2 * V^2... T=H/(2*G*H)^-1/2
10/(2*10*9.81)^-1/2= 0.713921561 SECONDS
V=H/T 10/0.713921561 ms^-1 = 14.00714105
ii)
K.E. =1/2 * MV^2
1/2 * m *14.007^2 = 98.098MJ M is still in the equation as the mass is unknown
20% of the energy is now taken off
98.098MJ - ((98.098MJ/100)*20)= 78.4784MJ
V^2=(2*K.E.)/M
(78.4784MJ* 2)/M=156.9568
H=(1/2 * V^2)/G
H=(1/2*156.9568)/9.81= 8m Height at first bounce
Here is where i had the trouble
Im tring to find the time of the 2nd bounce but it works out smaller that the 1st bounce
78.4784MJ-((78.4784MJ/100)*20)= 62.7827MJ
V^2=(2*K.E.)/M
(62.7827MJ*2)/M= 125.56544
H=(1/2 * V^2)/G
H=(1/2*125.56544)/9.81= 6.3998m
T=H/(2*G*H)^-1/2 OR T= H/V 0.571125223
T=6.3998m/(2*9.81*6.3998)^-1/2 =0.571125223 seconds this value is smaller than the first value
I have genuanly attempted this and have been working on it over and over for a number of hours with our any progression, I would apprechate any advice
The time for a bounce should decrease with each bounce.
Try it yourself! Find a ball and bounce it. (Ball bearings on hard metal work especially well: Tink...Tink..Tink tink tink tnktnktnktkkkkkkkk...)
QUOTE]
I know but due to my calculations it doesn't n I don't know where I have gone wrong
Oh! Okay, so right off the bat I see one big mistake, in your 'relevant equations' section.
V=h/t
well, that's only true if the velocity is constant. But the ball is accelerating! Also, it follows that T=H/(2*G*H)^-1/2 is not, in general, true.
You got the right first velocity, but it was a total coincidence. You also got the first time wrong.
ALSO, V=Sqrt[2*g*H] gives you the velocity right before the ball hits the ground, not at any other time in the fall. You probably already knew that, but I thought I'd check to make sure.
Hang in there! This is a really cool problem, and it's worth figuring out.
It seems like you need a bit more help. I'll explain the approach that I used.
First, let's figure out t1, the time at which the ball hits the ground for the very first time. This requires the equation relating distance to time in a constant acceleration situation, that is, d=1/2*a*t^2. Here, d is Ho, the height of the building. a is acceleration due to gravity, g. So put it together, and get t1.
Now on to higher t's. t2=t1+(the time it takes for the first bounce arc). I used a trick to get this. I realized that, if the ball loses 20% of its KE, then the next bounce wil only go .8 the height of the first bounce, so H1=.8Ho. Then I used the same process I used to get t1, except I also multiplied by 2 (because the ball has to go up to the top of the arc, then come back down).
And then on to t3! t3=t2+(time it takes for second bounce arc). Now the maximum height of the bounce is reduced by another 20%. Can you see where this is going?
Now for the velocities- you want the v right before the velocity of the ball hits the ground? Well, at that point, it will have zero potential energy (using the ground as baseline, of course), so all of the potential energy it had at H-whatever will be KE.
I hope that helps!
Looks like a double post to me. Moderator?
  • · Replies 38 ·
  • · Replies 25 ·
  • · Replies 21 ·
