What is the most efficient and powerful way to store energy?
The discussion revolves around the most efficient and powerful methods of energy storage, with a focus on theoretical concepts such as matter-antimatter storage and practical examples like pumped-water storage. Participants explore various definitions of "powerful" and the constraints involved in energy storage technologies.
  • Some participants propose that matter-antimatter energy storage is the most mass-dense form of energy storage, suggesting it has the highest storage density.
  • Others argue that while antimatter has high storage density, current technology makes it extremely difficult and energy-intensive to produce and store.
  • A participant mentions a pumped-water storage facility in Michigan as a practical example of energy storage that can generate significant power for several hours.
  • There is a discussion about the efficiency of energy conversion, with some participants noting that antimatter is 100% efficient at converting to energy when combined with matter, but the infrastructure for its production and storage is inefficient.
  • One participant challenges the notion of efficiency by comparing it to conventional batteries, stating that while batteries can be over 90% efficient, antimatter storage involves significant energy losses in the production process.
  • Speculative ideas are introduced regarding the potential annihilation of a Planck black hole with its antiparticle and the Higgs mechanism at the inflationary scale.
  • Another participant asserts that while heat can be produced efficiently, it does not equate to energy storage, emphasizing that matter itself is the most powerful storage of energy due to its conversion to energy when combined with antimatter.
Participants express differing views on the definitions of "powerful" and the efficiency of various energy storage methods. There is no consensus on the best approach or technology, and multiple competing views remain throughout the discussion.
Participants use varying terminologies and definitions, leading to potential misunderstandings. The discussion highlights the complexities of energy storage efficiency and the challenges associated with different methods, particularly antimatter.
FoxCommander
What is the most powerful battery or way to store energy?
I have an idea but I wanted to see what you guys would say :)
Powerful by what definition and what constraints do you put on this? Matter-anti-matter energy storage is probably the most mass dense.
Correct answer. Fusion would come in a very distant second.
I agree that anti-matter is the ultimate in storage density. I love the stuff, and would like some to play with. Our current technology, however, makes it just about the most difficult and energy-intensive substance to produce and store.
Ok good, The other day i was thinking about it and It came to me that anti matter is created when you create matter from energy so i figured it was the most powerful "battery" in the context that it stores energy
Thanks guys I just wanted to make sure :D
When in doubt, watch Star Trek. :biggrin:
Fermilab usually has up to 50 (circulating current) milliamps of anti-protons stashed in the 8-GeV cooling ring. Unfortunately, no one has a magic (anti-matter) box to put them in.
There is a pumped-water storage facility in Ludington, Michigan, that stores enough water (pumped uphill from Lake Michigan) to generate about 1800 megawatts for roughly 8 hours.
Bob S
By that, you mean among the least energy efficient storage/release mechanism, yes. Ie, a battery is better than 90% efficient at storing and giving back its energy.
I'm not sure if that's what I meant or not, Russ; we appear to be using incompatible terminologies. I'll explain myself more fully.
The anti-matter itself is 100% efficient at converting to energy when combined with matter, so in that sense it has the highest storage density. It's in the required infrastructure that the problem lies. A very rough analogy would be the need to build an entire factory to produce a single AA battery, an elaborate semi-trailer to lug it around, and another factory to collect the energy at the end. As if that weren't bad enough, the first factory puts 1000 volts into the battery and the second one can extract only 1 volt due to collector inefficiencies.
To be more specific, the potential annihilation of a Planck black hole with its antiparticle.
Otherwise, the symmetry of the Higgs mechanism at the inflationary scale. (This is mostly speculation on my part.)
The anti-matter itself is 100% efficient at converting to energy when combined with matter...
Right. The inefficiency comes in the charging.
...so in that sense it has the highest storage density.
Ehh, well, no. If heat is the goal, there are lots of ways to store energy that output 100% efficiency. A car battery powering a heater is 100% efficient at producing heat, for example.
That's the part I was describing.
russ_watters said:
Right. The inefficiency comes in the charging. Ehh, well, no. If heat is the goal, there are lots of ways to store energy that output 100% efficiency.
Ok this is completely false because the amount of energy put into heater is not the same amount of heat energy given off, you are sadly mistaken.
Anyways what is heat? Its energy. And what is pound for pound the most efficient and powerful storage of energy? Well its matter, because when you create an amount of matter the same amount of Anti-matter is created, and when you put the two together you get pure energy.
A heater produces heat. But does all of the energy it uses wether mechanical or electrical go into the heating and therefore 100% efficient? NO And on that note, A heater doesn't store energy. It converts it
Sincerly,
FoxCommander
  • · Replies 29 ·
  • · Replies 18 ·
