What is the heat flow through the ceiling into the attic in 4.5h?
The heat flow through the ceiling into the attic over 4.5 hours is calculated using the heat current equation with thermal resistance. Given a ceiling area of 135 ft², an R-value of 30, a room temperature of 63°F, and an attic temperature of 38°F, the correct calculation yields a heat flow of 112.5 BTU over 4.5 hours. This is derived from the formula H = [A(Th-Tc)] / R, resulting in H = [(135)(25)] / [30] = 112.5 BTU/h. The conversion to joules is also necessary for complete understanding.
  • Understanding of thermal resistance and R-values
  • Familiarity with heat transfer equations
  • Basic knowledge of temperature scales (Fahrenheit)
  • Ability to perform unit conversions (BTU to joules)
  • Study the principles of heat transfer and thermal resistance
  • Learn about unit conversions between BTU and joules
  • Explore advanced topics in thermodynamics related to insulation
  • Practice similar problems involving heat flow calculations
Students in physics or engineering courses, HVAC professionals, and anyone interested in understanding heat transfer principles and insulation effectiveness.
tquiva
The ceiling of a room has an area of 135ft^2. The ceiling is insulated to an R value of 30 (in units of ft^2*deg. F*h/Btu). The surface in the room is maintained at 63 deg. F, and the surface in the attic has a temperature of 38 deg. F. What is the heat flow through the ceiling into the attic in 4.5 h?
Express your answer in (a) BTU and (b) joules.
The equation I used was the heat current equation with thermal resistance.
H = [A(Th-Tc)] / R
H = [A(Th-Tc)] / R
= [(135ft^2)(63 deg. F - 38 deg. F)] / [30 ft^2*deg. F*h/BTU]
= 3.8 BTH / h
I've already made an attempt to this problems and my results don't seem to not be right. Can someone please help me?
135*25/30 is not 3.8.
  • · Replies 26 ·
