First Order Homogeneous Differential Equations
The discussion focuses on solving first-order homogeneous differential equations, specifically the equations \(\frac{du}{dx} = \frac{4u-2x}{u+x}\) and \(\frac{du}{dx} = \frac{xu+u^{2}}{x^{2}}\). The first equation can be approached using the substitution \(y = u + x\), leading to a transformed equation \(\frac{dy}{dx} = 5 - \frac{6x}{y}\). For the second equation, the substitution \(y = \frac{u}{x}\) is recommended to simplify the problem and make it separable, facilitating the solution process.
  • Understanding of first-order differential equations
  • Familiarity with homogeneous functions
  • Proficiency in substitution methods for differential equations
  • Knowledge of separable differential equations
  • Study the method of substitution in differential equations
  • Learn about homogeneous functions and their properties
  • Explore techniques for solving separable differential equations
  • Practice solving first-order differential equations using various substitutions
Students and educators in mathematics, particularly those focusing on differential equations, as well as anyone seeking to enhance their problem-solving skills in this area.
drcameron
Find the general solution of the following homogeneous differential equations:
(i) [tex]\frac{du}{dx} = \frac{4u-2x}{u+x}[/tex]
(ii) [tex]\frac{du}{dx} = \frac{xu+u^{2}}{x^{2}}[/tex]
(You may express your solution as a function of u and x together)
There are no relevant equations to this solution
(i) [tex]\frac{du}{dx} = 4 - \frac{6x}{u+x}[/tex]
I could then use the substition y=u+x with dy/dx = du/dx + 1 to give:
[tex]\frac{dy}{dx} = 5 - \frac{6x}{y}[/tex].
Now I'm really lost as shouldn't the y be on the top or am I missing something really stupid here?
(ii) Similar problem to above - should get it from (i) but a hint would go a long way.
The usual trick in the homogeneous case it to use the substitution y=u/x. Did you try that? It should make it separable.
Many thanks, using a more appropriate substitution helps a lot. The second equation then just fell into place for me as a result.
  • · Replies 18 ·
