Calculating Volume of a Gas Tank/Gas within
  • Thread starter Thread starter marcus768
    Gas Volume
The problem involves calculating the volume of gasoline in a cylindrical gas tank that is buried on its side. The tank has a radius of 4 feet and a length of 22 feet. The original poster seeks guidance on developing an integral to find the volume of gas based on the depth of the gasoline level, h, and is particularly interested in understanding the underlying concepts rather than receiving direct answers.
  • The original poster attempts to set up an integral using the formula for the volume of a cylinder and is exploring the relationship between the radius and the variable height. They question how to express the radius in terms of height. Other participants suggest focusing on the wet area of the tank's end and multiplying it by the length to find the volume. There is discussion about the need to calculate the area of the wet portion based on depth h.
Participants are actively exploring different methods to set up the integral for calculating the volume. Some guidance has been offered regarding the approach to finding the wet area and its relation to the overall volume. There is a recognition of the need to clarify the setup of the integral without reaching a consensus on the final method.
The original poster expresses confusion regarding the setup of the integral and the relationship between the variables involved. There is an emphasis on understanding the concept rather than simply obtaining a solution, which aligns with the forum's learning-first approach.
marcus768
I am taking a calc 2 class and I'm studying for finals. I've got this problem i need to figure out and I am having a tough time with it. if someone could give me some guidance in solving this I would greatly appreciate it. I am not looking for answers to this assignment - I would really like to understand how this problem is working, since similar problems will presumably be on the final. If anyone could help guide me through this I would really appreciate it.
A cylindrical gas tank with radius 4ft. and length 22ft is buried on its side.
-Develop an integral that could be used to find the volume of gas in the tank and number of gallons of gas in the tank, given the depth of the gasoline level h
- Test the integral by using it to find the amount of gas in the tank (by vol in cubic ft and gallons) for h=8 ft (full) h=4ft h=0ft h=6 ft
I am trying to see if I can set up my integral in a way where it is not dependent on height. V=(pi)(r)^2L is what I have been trying. I am trying to set up my integral in disc format. V=(integral sign) pi[f(x)]^2dx
So what I've been trying to do is first create a function with the V=(pi)(r)^2L formula. Since the radius is given, and the length is given also, where is my variable? Is my radius (4-x)? I guess I am having trouble understanding how to set up the integral. When it comes to evaluating the integral, I am fine. i really need to understand this concept, I am not looking for answers.
any help is appreciated very much, thank you
Suppose you are looking directly at the end of the tank, which is a circle of radius 4. Suppose the water is to depth h. Can you set up an integral to calculate the wet area of the end of the tank? The answer, of course, will depend on h. And the volume of water in the tank is just L times the wet area, no?
Ok, so by using the formula for volume of a cylinder V=pi*(r^2)h
I am coming up with V=pi((4-x)^2)22
I have been trying to use the integral format V=(integral)A(h) dh
I am getting V= (integral evaulated from 0 to 8) (pi(4-x)^2)22
After I evaluate the integral, I am getting approx 2949. This is way off to what it should be, when I use the formula for vol. of a cylinder I get
V= pi(4^2)22 = approx. 1105.
I do not get where I am going wrong!
Did you even read my post? You don't need to integrate the cross section area along the length of the tank. All the cross sections are the same. You need to calculate the area of the wet portion of the end for a depth h and multiply it by the length of the tank to get the volume of water.
Can you set up the integral for the area of the end covered when the water has depth h? That is what you need to do.
  • · Replies 109 ·
10K
  • · Replies 33 ·
