Does Hydrogen Injection Improve Diesel Engine Efficiency and Reduce Pollutants?
  • Thread starter Thread starter jackmccarron
    Hydrogen
The discussion centers around the potential benefits of hydrogen injection in diesel engines, specifically regarding improvements in fuel efficiency, power output, and reductions in pollutants. Participants explore the mechanics of hydrogen combustion and its implications for engine performance, including theoretical efficiency claims and practical considerations for implementation.
  • One participant expresses interest in using hydrogen injection to improve fuel mileage and power in a Dodge diesel truck, citing potential increases in burning efficiency from 75% to 90%.
  • Another participant challenges the claim of 75% efficiency, suggesting it exceeds theoretical limits for diesel engines and questions the feasibility of electrolyzing water for hydrogen production.
  • Concerns are raised about the energy input required for electrolysis and whether the energy output from burning hydrogen would exceed the energy input.
  • Participants discuss the volume changes during and after the combustion of hydrogen and oxygen, with one asserting that the volume would halve due to the formation of water, while another questions the assumptions about temperature effects.
  • A thought experiment is proposed regarding the behavior of a rising bubble of hydrogen and oxygen in water when ignited, with one participant seeking clarification on the expected volume changes during combustion.
  • Hydrogen embrittlement and its potential long-term effects on engine materials are mentioned, with some participants expressing uncertainty about the timeline for any potential issues.
  • Alternative methods, such as propane injection, are also discussed as viable options for enhancing diesel engine performance.
Participants exhibit disagreement on the efficiency claims of diesel engines and the practicality of hydrogen injection. There is no consensus on the effects of combustion on gas volume or the implications for engine health over time.
Participants reference various assumptions about thermodynamics, efficiency metrics, and the practicalities of implementing hydrogen injection systems, but these assumptions remain unresolved and are subject to differing interpretations.
Individuals interested in alternative fuel technologies, diesel engine performance enhancement, and the implications of hydrogen combustion in automotive applications may find this discussion relevant.
jackmccarron
I'm interested in hydrogen injection for my 1 ton Dodge diesel truck to improve fuel mileage and power as well as lower pollutants. Electrolysing water to produce a stoichiometric mixture of hydrogen and oxygen (called HHO or hydroxy or "Brown's gas") and then injecting it into the turbo intake is supposed to significantly improve the burning efficiency of the diesel fuel (like from the normal 75% to 90%)
I want to ask a question about burning the gas mixture of hydrogen and oxygen (2H+O). Namely, what happens to the volume of the mixture during and after the explosion. Does the volume increase (due to heat) or decrease (if the gas "collapses" to water)? Since the initial result is probably steam, does the resulting steam occupy more or less volume than the original gas? (I assume more since the number of moles of gas hasn't changed, and it's now hotter.) If the original gas were a rising bubble in water when detonated, I assume the bubble would at first get larger and then vanish as the steam condenses to liquid water. Is this correct?
If my assumption is correct, if you have a certain volume of the gas is at room temp and sea level pressure, approximately at what temperature and what volume would the steam occupy at the instant the combustion is complete?
For more info on hydroxy injection, see
http://burnhydrox.com/customers.html
Thanks,
Jack
Chemistry news on Phys.org
It won't.
i would be surprised if your current dodge engine is 75% efficient, that's about 10% more than the theoretical efficiency of a diesel ICE.
How exactly were you planning on electrolysing the water? Where does the energy to do that come from?
Do you think you are likely to get more power out than you put in?
2 moles of H2 and 1 mol of O2 will form 2 moles of H2O, so the volume will halve.
Except the temperature will go up, so you need to know what the initial and final temperatures will be,
The number of moles of gas has changed.
No idea what you mean here
ps You might want to consider what doing this will do to the engine of your truck.
i assume you know more about the thermodynamics, metallurgy, hydrogen embrittling and oxygen compatibility of the materials than the makers.
pps. Sorry if you aren't a crank!
The water-gas car injection thing comes up regularly here.
It's normally followed by the sort of logic that goes -
I use the output of the alternator to make H2/O2 that makes more power - which means I can make more H2O2. And pretty soon they are planning to use their Chevy to power Chicago.
Then it's followed by a belief that everyone could do this if the car companies weren't in the pay of the oil companies.
Then when somebody here questions the wisdom somebody without high school chemistry trying to inject oxygen at 1000bar into an aluminium engine full of various flammable fuels - it's because we are part of the conspiracy.
to mgb_phys: "i would be surprised if your current dodge engine is 75% efficient, that's about 10% more than the theoretical efficiency of a diesel ICE.
How exactly were you planning on electrolysing the water? Where does the energy to do that come from? Do you think you are likely to get more power out than you put in?"
Sorry, I read somewhere in the web that the usual efficiency of a diesel is 75% burned fuel. Not knowing any better I quoted that number.
I Would plan to get hydroxy (HHO, or OxyHydrogen) from electrolysis of water (with KOH catalyst ) using 12volt power from anternator/battery. Of course I don't expect more power out from just burning the HHO. I understand the 2nd law of thermodynamics. The gain in overall power comes from more efficiently burning the diesel fuel itself. My understanding is that the injection of gaseous hydrogen (or propane or methane) into the diesel fuel causes it to burn much faster and more completely. Normally (without hydrogen injection), I'm told, the diesel fuel continues to burn for the entire downward travel of the piston during the power stroke - and even somewhat into the exhaust stroke, wasting energy. Faster burning of the diesel allows the capture of significantly more of the chemical energy of the diesel fuel. This would imply higher initial pressures within the cylinder, but I've heard no "stories" about blown head gaskets, etc."2 moles of H2 and 1 mol of O2 will form 2 moles of H2O, so the volume will halve.
Except the temperature will go up, so you need to know what the initial and final temperatures will be,"
So why wouldn't the volume be 2/3 not 1/2? (disregarding effects of temperature change.)
"If the original gas were a rising bubble in water when detonated, I assume the bubble would at first get larger and then vanish as the steam condenses to liquid water. Is this correct?
No idea what you mean here"
This was just a thought experiment to visualize the volume change when burning HHO. Picture a large bubble of HHO rising in a column of water. If the bubble could somehow be ignited while it traveled upward (like passing over a spark plug), how would the bubble behave as the HHO burns? As the hydrogen/oxygen mixture burns, I would assume it "instantly" converts to hot steam at some (probably larger?) volume. Then as the steam condenses (being surrounded by cool water) it enters the liquid water phase, joins the surrounding water and the bubble "vanishes". Does this seem correct?"ps You might want to consider what doing this will do to the engine of your truck.
i assume you know more about the thermodynamics, metallurgy, hydrogen embrittling and oxygen compatibility of the materials than the makers."I have wondered about hydrogen embrittlement, and have checked the internet on this. Nobody I found has any definite info on this, but most seem to think it would take years to cause any problem. May or may not be true. Actually, I'm more likely to go with a propane injection system, although this obviously requires buying propane and storing it onboard the truck (danger!).
Propane injection into diesel engines has be used since the early 1900s in farm tractors. It is being used by many power enhanced diesel trucks today with apparently little affect on the engine. Instead, I've heard from several truck mechanics, that the most common problem is failed transmissions - as the heavy footed boys show off their trucks. I'm an old fart (full-time RVer and retired EE) who's interested in fuel economy, not how fast I can leave the stoplight. According to most of the internet info I've found, propane, hydrogen, HHO, and methane can all be used to get the diesel fuel burning acceleration effect. This also reportedly works with gasoline engines. However, some adjustment to the car's oxygen sensor feedback to the ECU is necessary. See http://www.hho2u.com/OXYGEN_SENSORs.html if you're interested.
  • · Replies 39 ·
9K
