Limit of the form 0^infinity+infinity^0
  • Thread starter Thread starter abhineetK
    Form Limit
The discussion revolves around evaluating the limit of the expression involving sine and reciprocal functions as x approaches 0 from the positive side. The problem is situated within the context of limits and indeterminate forms in calculus.
  • Participants explore the limit by breaking it into two parts and considering the behavior of each as x approaches 0. There are discussions about using logarithmic properties and L'Hôpital's Rule to analyze the limits. Some participants express confusion over the differing results obtained and question the assumptions made regarding the limits.
The discussion is ongoing, with various interpretations of the limits being explored. Some participants have suggested potential approaches, while others are questioning the validity of the results and the steps taken to arrive at them. There is no explicit consensus on the correct limit value at this stage.
Participants note that the limit is evaluated as x approaches 0 from the positive side, which is a critical aspect of the problem. There is also mention of different potential answers being provided, leading to further inquiry into the correctness of those answers.
abhineetK
What is the value of
lim {(1/x)sinx+(sinx)1/x} ,x>0 ?
x->0
x->0
=lim (1/x)sinx+lim (sinx)1/x
..x->0...x->0
Let A=lim (1/x)sinx
...x->0
and B=lim (sinx)1/x
...x->0
logA=lim (sinx)log(1/x)=0
...x->0
=>A=e0=1
logB=lim (1/x)log(sinx)=infinity
...x->0
=>B=infinity
The problem is that the answer is 0.
I understand that x goes to 0 in the limit, but how ? [itex]\nearrow 0[/itex] or [itex]\searrow 0[/itex] ?
Split it up into two limits and work with them. If both limits exist, then their sum will be the limit you want.
Since both expressions involve exponents, you are most likely going to have to take the log, which will probably get you something you can use L'Hopital's Rule on.
I discussed this problem with someone..
He says,
lim (sinx)1/x=1
x->0
So, according to him answer must be 2.
I worked it out again and got the same answer, i.e., infinity...
How is it happening...??
Please, show the steps if you have got the answer 2, 1 or 0.
These were the options given to me...
However, if you feel that the correct answer is not among the options please tell with explanation and steps.
I believe the limit in your first post is 1, but I can't justify it just yet. (sin x)^(1/x) -->0 as x -->0+, and (1/x)^(sin x) --> 1 as x --> 0+. I'll see if I can provide some justification for this result.
As x approaches 0 from above. (The OP said that x > 0.)
Let y1 = (1/x)sin x
Then ln y1 = ln[(1/x)sin x] = sinx*ln(1/x) = sinx*(-lnx) = -lnx/cscx
In the next step I use L'Hopital's Rule, since we have an indeterminate form of [infinity/infinity]. Also, in the following steps, lim means limit as x -->0+
lim ln[ ln y1] = lim [-lnx/cscx]
= lim [(-1/x)/(-csc x * cot x)] = lim[(1/x)/(csc x * cot x)]
= lim[(1/x)/(1/sinx * cos x/sinx)] = lim [sin^2(x)/(x cos x)]
= lim [(sin(x)/x * tan(x)] = lim[sin(x)/x]*lim tan(x) = 1*0 = 0.
Since lim ln y1 = 0, ln lim y1 = 0, hence lim y1 = 1.
The other limit is easier.
Let y2 = sinx1/x = (eln(sinx))1/x = e(1/x)ln(sin x)
Before taking the limit, let's look at what the factors in the exponent on e are doing as x --> 0+.
1/x --> + infinity.
sin(x) --> 0+, so ln(sin(x)) --> -infinity.
The product of 1/x and ln(sin(x)) --> -infinity.
Since the exponent on e is approaching -infinity, then e to that power --> 0.
Hence lim y2 = lim e(1/x)ln(sin x) = 0.
Therefore lim (y1 + y2) = 1 + 0 = 1.
36K
