Understanding Boiling Point: Factors That Affect Liquid Vapor Pressure
The boiling point of a liquid is defined as the temperature at which its vapor pressure equals atmospheric pressure. However, factors such as water pressure at different depths and the shape of the container can influence the boiling point. In a heated flask, the bottom water is hotter than the surface water, leading to variations in boiling point. This principle is exemplified by geysers, where superheated water expands and causes explosive boiling when pressure is released.
  • Understanding of vapor pressure and boiling point concepts
  • Knowledge of fluid dynamics, particularly in relation to pressure changes
  • Familiarity with thermodynamic principles
  • Basic laboratory techniques for heating liquids
  • Research the relationship between vapor pressure and temperature in liquids
  • Explore the effects of container shape on boiling point
  • Study the mechanics of geysers and superheated water phenomena
  • Learn about pressure variations in fluids and their impact on boiling
Students in chemistry and physics, researchers studying thermodynamics, and anyone interested in the principles of boiling and vapor pressure in liquids.
swiss729
Hello!
I often read that the boiling point of a liquid is when its vapor pressure is equal to the atmospheric pressure. What I don't understand is why they never take the pressure of the water into consideration? Doesn't water pressure increase as depth increases and wouldn't this have to be overcome in addition to the atmospheric pressure? Thanks for the help!
Chemistry news on Phys.org
Yes. The temperature of the water at the bottom of the flask will have a slightly different boiling point than the water at the surface. Usually the flask is being heated from the bottom so that part is hotter than the water near the top. The shape of the flask can seriously change the BP by the way. That is how geysers work. Water at the bottom of the crevice (think of it as a column of water) is superheated and expands, pushing out the water from the top of the column. Once that water's weight has been removed to a certain extent, explosive boiling results shooting the remaining water into the sky.
In the lab, the effect is very small and is neglected.
  • · Replies 31 ·
  • · Replies 115 ·
12K
