Paralell Inductors in a DC Circuit with Constant Current
The discussion centers on calculating the energy stored in parallel inductors in a DC circuit with a constant current source of 2A. The original poster questions whether the current splits evenly among the inductors when they reach steady state, suggesting that if the total current is 1A, each inductor would receive a fraction of that current. However, a response clarifies that in a DC scenario, the current division cannot be determined solely by the inductance values without considering additional circuit elements like resistors. The response suggests that a transient analysis may be necessary to accurately assess current distribution.
  • Understanding of basic circuit analysis principles
  • Knowledge of inductor behavior in DC circuits
  • Familiarity with energy storage equations for inductors
  • Concept of current division in parallel circuits
  • Study the behavior of inductors in DC steady state conditions
  • Learn about transient analysis in electrical circuits
  • Explore current division rules in parallel circuits with resistive elements
  • Review energy storage calculations for inductors using the formula w = (1/2)*L*i^2
Electrical engineering students, circuit designers, and anyone involved in analyzing DC circuits with inductors will benefit from this discussion.
Peddler1010
Hi,
This isn't so much of a home work problem just a request for clarification from those that are more intelligent than I. I actually just wrote the final for Basic Circuit Analysis and there was a question that left me totally stumped.
I've attached a VERY crude, much less complicated version of the question..er..in question.
We were given a network of inductors and asked to find the equivalent inductance between a particular set of terminals. Easy enough. We were then asked to find the energy stored in each individual inductor if a 2A current source is attached between the terminals.
My question then, is this (Have a look at the diagram): Since inductors act like short circuits in DC when at their steady state, can I (as I did in the exam) assume that the current from the source (I1) splits evenly through the two branches. So if I1 is 1A, then L3 sees .5 Amps and L1 and L2 both share .5A. Since they are in parallel they would both see .25 A.
And then w = (1/2)*L*i^2 for each of the L's with their respective i's.
Is that even close to correct? The question was a lot more complicated than the simple version that I showed you here, but it was worth like 5/100, so I can't see the solution being that tough.
Anyway, I would really appreciate even just a Yes or No answer to this.
Thanks a lot.
Peddler1010 said:
Hi,
Thanks a lot.
Welcome to the PF. For DC, inductor currents need to be defined by something other than their inductance. Either their DCR, or some other rresistors somewhere in the circuit, or something would have to define it. Having two ideal inductors in parallel being fed by a current source, there is no way I know of to determine how the current might divide.
Maybe you could ramp the current up at some rate, which would give you current division according to their inductances, and then argue that when there is no change in current at the DC top of the ramp, the two currents will stay constant, at that divide ratio? Hmm, maybe try that math to see if it works out. But that only works if there is an initial transient aspect to the current source. Although maybe that can be assumed, since the circuit had to be turned on at some point in the history of time...
  • · Replies 18 ·
