Put my dead hard drive in the freezer
  • Thread starter Thread starter Artman
    Drive Hard
The discussion revolves around a personal experience with a failed hard drive and the unconventional method of placing it in a freezer to recover data. Participants explore the effectiveness and potential risks of this approach, as well as considerations regarding hard drive design and data backup practices.
  • One participant successfully recovered data from a mechanical hard drive by freezing it, which temporarily freed up the spindle motor.
  • Another participant expresses appreciation for the tip, indicating a positive reception to the method.
  • Questions are raised about the potential for frost to affect the hard drive's platters, heads, or electronics, suggesting the use of desiccant packs to mitigate moisture risks.
  • Some participants assert that hard drives are well-sealed to prevent moisture buildup, which may alleviate concerns about condensation.
  • A participant mentions that newer hard drives often have a breather hole for pressure equalization, which could be a factor in the freezing method's effectiveness.
  • There is a discussion about the definition of a proper backup, with one participant noting that backing up data on the same drive does not constitute a true backup.
Participants express a mix of agreement and uncertainty regarding the effectiveness and safety of freezing hard drives. While some support the method, others raise concerns about potential risks, indicating that the discussion remains unresolved on these points.
Participants discuss the design features of hard drives, including airtight seals and breather holes, which may influence the outcomes of the freezing method. There are also varying opinions on what constitutes a proper backup strategy.
Artman
My wife's computer hard drive failed the other day. She backed up her data, but on a partition on the same drive. The failure was mechanical, the spindle motor froze up. So accessing the backup partition was also out of the question. I was afraid we were doomed, but I read about people who had this problem and put the drive in the freezer to contract and free up some of the moving metal parts.
I put the drive in my freezer overnight. The next day I placed it in a USB external hard drive enclosure, connected that to my laptop, powered it on and the drive spun up and worked for about an hour and a half before slowing to a stop again, long enough to retrieve most of my wife's critical documents.
Thought I'd share this with you all in case something similar ever happens to you.
Computer science news on Phys.org
Cool tip! Thanks. (oops, no pun intended)
Wooo...good job dude.
And yes, was it a Seagate HDD?
Would there be concerns about frost getting on the platters / heads or electronics? I guess you could just throw some dessicant packs in a big ZipLock back with the drive and not leave it for more than a day or two.
Hard drives are air tight and very well sealed to prevent dust or other contaminants entering them so a build up of moisture due to cold temperatures isn't an issue.
I think most new hard drives now have little filtered vent or 'breather hole' to equalize pressures, along with an attendant "Do not cover this hole!" warning sticker on the outside:
http://en.wikipedia.org/wiki/Hard_disk_drive#Integrity
I did not mention it, but I did put the drive in a ziplock bag, but never thought about adding some desiccant packs. That is a good suggestion.
I was concerned about condensation effecting the electronics or platters, but it seemed to stay pretty dry.
dE_logics, no, it was not a Seagate. I'm not where I can get to the drive right now, but I think it was a Toshiba.
Well, that's not a backup, techincally...
Nope, but I admire you ingenuity, and hope you used that time to make another copy!
10K
11K
9K
  • · Replies 30 ·
