Gravitationally trapped photons leads to quantized space-time
The discussion centers on the concept of gravitationally trapped photons and the implications for quantized space-time. Participants explore the theoretical framework surrounding photons in strong gravitational fields, particularly in relation to their energy, angular momentum, and the potential connections to string theory.
  • One participant proposes a model where a photon with sufficient energy could be trapped in its own gravitational field, leading to a quantized area of space-time.
  • Another participant suggests that there is a need for new physics at the Planck level, particularly when considering a photon's wavelength in relation to its Schwarzschild radius.
  • A third participant challenges the assumptions made in the initial derivation, arguing that a transition to special relativity is necessary for proper analysis.
  • Another participant points out that the Schwarzschild radius remains valid under general relativity, emphasizing the need for careful application of gravitational concepts.
  • One participant critiques the application of Newtonian theory to light and general relativity, highlighting a flaw in the derivation that leads to a radius inside a black hole's event horizon.
Participants express differing views on the validity of the initial assumptions and the application of Newtonian mechanics to photons in gravitational fields. There is no consensus on the correctness of the proposed model or the implications for quantized space-time.
Limitations include unresolved assumptions regarding the transition between classical and relativistic physics, as well as the implications of applying Newtonian mechanics to light in a general relativity context.
johne1618
Hi,
I was wondering what happens if one has a photon that is so energetic that it gets trapped in its own gravitational field.
Imagine a mass m orbitting a large mass M in a circular orbit with radius r and with transverse velocity v. By equating the gravitational force on m with its centripetal acceleration we have:
G M m / r^2 = m v^2 / r
Now let velocity v approach the speed of light c. The mass m will be boosted by a Lorentz factor but I think the equation should still hold so that we have:
G M m / r^2 = m c^2 / r
Thus cancelling m we have:
M = (c^2 / G) r
or in terms of Energy E = M c^2 we have
E = (c^4 / G) r (*)
This is the energy that a photon must have to get trapped in its own gravitational field so
that it orbits in a circle with radius r. The quantitiy c^4 / G is also the string tension so maybe this is also a model of a string.
Now let us suppose that the photon has angular momentum hbar. Then we have
r * p = hbar
where p is the linear momentum of the photon.
Now we know that p = E / c for photons so that we have:
r * E / c = hbar
E = hbar * c / r
E = h * c / 2.pi.r
E = h / t (**)
where t is the time period of the photon orbit.
If we substitute E=h/t into equation (*) we get:
h / t = (c^4 / G) * r
Rearranging we get:
r * t = h G / c^4
Thus we find that the spacetime area occupied by this bound photon, r * t, is quantized.
I was wondering if this is similar to the result that the world sheet area swept out by strings is quantized.
That's why we know there is New Physics at the Planck level. The whole world wants to know what happens when a photon's wavelength is smaller than it's scharzchild radius. i. e. at the Planck energy/length.
In addition, the assumption
"'Now let velocity v approach the speed of light c. The mass m will be boosted by a Lorentz factor but I think the equation should still hold so that we have:
G M m / r^2 = m c^2 / r"
.. is not suitable. Transition to special relativity is needed.
The schwartzchild radius r=2MG/c^2 is valid even when general relativity is considered.
A quick example of why mindlessly attempting to apply Newtonian theory to both light and general relativity is inadequate:
From your derviation you would no doubt agree for a circular orbit.
[tex]v=\sqrt{\frac{GM}{r}}[/tex]
Suppose we want to find the radius of a photon's orbit, so v=c, we get
[tex]r=\frac{GM}{c^2}=\frac{r_s}{2}[/tex]
Which is inside the event horizon of the black hole! Clearly, something went wrong along the way.
I'm not going to poke holes in everything you've written, but you should realize that your treating GR and photons so lightly is not appropriate.
  • · Replies 50 ·
13K
