Target Distance and Light Travel: The Impact on Spatial Position
  • Context: Undergrad
  • Thread starter Thread starter cfrogue
    Light
The discussion revolves around the behavior of light as it travels towards a target located at a distance d, particularly considering the motion of the Earth and the target. Participants explore the implications of relative motion, the frame of reference, and the constancy of the speed of light in different contexts.
  • Some participants question whether a target remains at the same spatial position as light travels towards it, particularly when considering the Earth's motion.
  • Others argue that the target's motion is dependent on its frame of reference, stating that if the target is stationary relative to the Earth's surface, it shares the same motion as the Earth.
  • A few participants suggest that the question may imply a misunderstanding of how the speed of light relates to the motion of the observer and the target.
  • Some contributions highlight that the speed of light is constant in all inertial frames and does not depend on the motion of the light source.
  • There are discussions about whether the target will move away from the light beam due to the Earth's orbital motion, with varying interpretations of how this affects the time it takes for light to reach the target.
  • One participant notes that the speed of the target relative to the light source is zero if both are fixed to the Earth, despite the target's motion relative to an external reference point.
Participants express differing views on the relationship between the motion of the target, the speed of light, and the frame of reference. There is no consensus on the implications of these factors, and the discussion remains unresolved.
Limitations include assumptions about the frame of reference, the relevance of the Earth's motion, and the ambiguity surrounding the term "motion" as it pertains to acceleration versus constant velocity.
cfrogue
If there is a target at a distance d and I shoot light at it, does it remain at the same point in space as light proceeds toward it?
For example, if the target in in line with the revolution of the Earth around the sun, will the target move away at 18.55 miles per second as the light proceeds toward it?
In general, no. The only case where it would remain at the same distance is if it were at rest in the frame in which the distance was measured.
r
Naturally, I was assuming we were on the earth.
So, light takes off at c and the Earth moves also and so does the target.
When light is shot at the target, and light proceeds in free space, will the target remain at rest even though the Earth is in orbit around the sun? In other words, will the target move away with the motion of the Earth as the light speeds toward it?
cfrogue said:
r
Are you asking if the target will accelerate or not depending on whether or not we shoot a light at it? Before the light even reaches it?
Can you rephrase? I'm sure that's not what you mean to ask.
The target is on the earth.
I still don't understand the question. If the target is stationary relative to Earth's surface, then its motion is the same as Earth's surface relative to the sun, ie both orbital and rotational motion. But that has nothing to do with shooting light at it.
Light is shot at a target.
I assume light shoots.
Now, when light shoots at a target in the direction of the Earth's orbit, will the target move?
If you say no, then the Earth is geocentric.
Of course the target will continue its existing motion if no force acts on it, but that has nothing to do with light being shot at it.
I still must not understand the question.
cfrogue said:
r
The source will move with its own motion, and the target will move with its own motion. Neither are constrained to any specific value and neither influence the speed of the light pulse.
Obviously the Earth is geocentric. That's the definition of geocentric.
You mean it doesn't depend on whether I say no or not? :eek:
Correct. The answer to scenario has nothing to do with whether or not the Earth is geocentric nor does what you say the answer to the scenario is.
The Earth is geocentric by definition. I would think that is blatantly obvious.
LOL. As far as I can tell the answer to the scenario (what is the motion of the target?), has nothing to do with any light being shot at it as well.
What is the point of the question? Is the target trying to dodge the light? :confused:
Perhaps the OP is backwardsly asking if the speed of light is dependent on the speed of the observer?
In the scenario given, the target and shooter are stationary with respect to each other. All that other stuff about the Earth's rotation and orbit are irrelevant.
I agree. The second postulate is that light travels at c in vacuum in any inertial frame regardless of any other factors.
According to what frame?
In the frame of the Earth, no. The light takes a time of d/c to reach the target.
In the frame of the Sun, then yes. The light proceeds towards the target at c, but the target moves away at the speed of 18.55 miles/sec. Thus the time it takes the light to reach the target is d/(c-18.55mps)
I think you mean the speed of light does not depend on the speed of the light source.
This has been verified by experiments that the speed of light cannot be altered by the motion of the light source.
Now, that being said, from the light source, light emits at c period regardless of the motion of the light source.
Is this correct?
Is this correct?
"Motion" is a little ambiguous. It is acceleration that can cause problems. The speed of light is constant in all inertial (non-accelerating) frames - ie, when the source and observer are not accelerating with respect to each other.
Also, I don't like the way "speed of the light source" is worded. Speeds are measured between two points. So hopefully, when you say "speed of the light source", you mean speed of the light source with respect to the target.
So for a concise answer to the OP:
It appears you are talking about a source and target both fixed to the earth. That means the speed of the target with respect to the source is zero, not 18.55 mi/s. That the speed of the target relative to some arbitrary point hanging in outer space is 18.55 mi/s is completely irrelevant.
So for a concise answer to the OP: It appears you are talking about a source and target both fixed to the earth. That means the speed of the target with respect to the source is zero, not 18.55 mi/s. That the speed of the target relative to some arbitrary point hanging in outer space is 18.55 mi/s is completely irrelevant.
Well, let's see if we can clear the light source thing up.
If a rocket rode by the Earth and when "parallel", the Earth and the rocket happen to shoot light in the same direction and parallel, would the light beams be located at the same x-axis distance in space at any time t in whichever frame looked at them?
Acceleration is a problem.
The metrics in an accelerated frame after acceleration is complete are expanded to
x/sqrt( 1 - (v/c)^2) compared to the originating frame.
Is the 18.55 number a pheudo absolute motion number or simply the speed around the sun.
I cannot find anything to validate this.
Of course, the milky way is doing something also.
Yes, I know.
But the geocentric model of the universe is similar to SR, no?
We are encouraged to consider the frame as the center of the inertial frame universe?
That is what it says, regardless of the motion of the light source.
Thus, for all possible light source motions relative to a frame, light will move at the same speed c in a vacuum of course.
I don't fully understand the OP's question, but I do know that if you shoot light across a playground roundabout to say some person sitting directly opposite to you, it will miss its target because of the coriolis effect. And since Earth rotates 1/day, you'll definitely miss on any experiment carried out on the surface of Earth.
So you can't just assume that because your target and source are stationary with respect to each other that your 'shoot light' will definitely hit the target.
Exactly (relative to an inertial frame).
So your initial concern or question is resolved?
Forgive me, but I've been reading with interest, and am having difficulty getting it to reconcile.
With a similar example, say we have the sun, Earth and a rocket ship armed with a laser.
The Earth is moving away from the sun at 18.55mps (assume this is in a straight line and ignore Earth's rotation)
The rocket ship is approaching the same distance from Earth as the sun, but is not moving relative to Earth (so will be traveling at 18.55mps). At the instant that the rocket ship and sun line up, the ship fires its laser to Earth and the sun emits its photons.
Now, If I am on Earth awaiting the light from both of these, it would seem that the rockets laser should get to me first as they only have the initial distance to travel.(it hasn't changed as we are not moving relative to each other.) But the light from the Sun had to travel a bit further as Earth is moving away.
Even if I add an extra observer out in space watching the whole thing (say he's still relative to the sun and watches the spaceship and Earth moving past). The instant the photons and laser are fired wouldn't he see the ships laser with more speed to the photons to account for the laser hitting first?
I know i must be wrong with these examples, I am currently thinking it has to do with the simultaneity of when the laser/photons are fired, but can't figure out in my head why and how it works.
You are correct, it is almost always due to the relativity of simultaneity. All reference frames agree that the rocket laser arrives first. In some frames it arrives first because it travels a shorter distance, in other frames it arrives first because it was fired first due to the relativity of simultaneity.
Yes, if they both struck the same target, each frame would agree that both light beams arrived at the target at the same time, but they would disagree about what specific time that is.
I have to disagree, DaleSmam, if I understand the question correctly. In each frame, the light from the ship and from the sun (solar flare?) left at the same time, since the events are local. In each frame, they would arrive at the target at the same time, since presumably, there could be an observer in each frame.
What the frames would disagree on is the specific time of the simultaneous arrival of the light beams at the target, and the distance from source to target.
Hmm, I understood his post differently. I understood the Earth to be in the middle and the sun and the rocket equidistant and on opposite sides. Perhaps the OP can clarify.
If you mean my question, then I meant the rocket and sun are on the same side, practically next to each other.
  • · Replies 90 ·
  • · Replies 26 ·
  • · Replies 65 ·
14K
  • · Replies 35 ·
  • · Replies 25 ·
  • · Replies 46 ·
