Relation between occupation probability and first passage probability
  • Context: Graduate
  • Thread starter Thread starter WiFO215
    Probability Relation
The discussion revolves around the relationship between occupation probability and first passage probability in the context of particle dynamics. Participants explore the implications of certain expressions and assumptions related to these probabilities, focusing on the mathematical formulation and underlying concepts.
  • Exploratory, Technical explanation, Debate/contested
  • One participant links to a previous post in a different sub-forum, indicating a lack of responses there and seeking insights here.
  • Another participant explains that the expression suggests a particle arriving at a position r at time t must have first arrived at that position at an earlier time t', with the delta function indicating the particle's initial position was at 0.
  • A follow-up comment raises a question about the assumption that the probability distribution P remains unchanged once the particle reaches position r, noting that this assumption is not explicitly stated.
  • Another participant points out an implicit assumption of stationarity, suggesting that the distribution is dependent only on the time difference rather than on absolute time.
Participants express differing views on the assumptions underlying the probability expressions, particularly regarding the constancy of the probability distribution and the implications of stationarity. No consensus is reached on these points.
The discussion highlights potential limitations in the assumptions made about the probability distributions, particularly concerning their dependence on time and the implications of stationarity. These aspects remain unresolved.
WiFO215
All the expression is saying is that a particle arriving at r at time t will have had a first arrival at r at time t' (which may = t) ahd then arrive at a relative position of 0 in time t-t'. The delta function term simply says that P(0,0) reflects the fact that it was at 0 to start with.
He is describing relative position zero using the same probability distribution P? So he is making the assumption there that P doesn't change once the thing reaches r? He hasn't mentioned this explicitly.
There is an implicit assumption of stationarity, i.e. the distribution depends only on time difference, not absolute time.
Okay! Thanks.
  • · Replies 57 ·
  • · Replies 23 ·
  • · Replies 23 ·
