Simple Coulomb's Law problem, struggling with basic calculus method
The problem involves calculating the force on a point charge due to a uniformly charged rod using Coulomb's Law. The setup includes a point charge +q at a distance d from one end of the rod, which has a total charge +Q and length L. The challenge lies in the integration required to account for the contributions from an infinite number of small charges along the rod.
  • The original poster attempts to set up an integral to calculate the force by considering an infinitesimal charge along the rod. They express uncertainty about how to express the distance r in terms of the variable dl for integration.
  • Some participants suggest rethinking the variable of integration, indicating that using l instead of dl may simplify the process. They also discuss the implications of r being double-valued over certain ranges.
  • Questions arise regarding the meaning of "double-valued" and the reasoning behind the length 2d, with participants seeking clarification on these concepts.
The discussion is ongoing, with participants exploring different perspectives on setting up the integral and clarifying the relationship between the variables involved. Some guidance has been offered regarding the choice of integration variable, but no consensus has been reached on the best approach yet.
Participants are navigating the complexities of integrating over a continuous charge distribution and the changing distances involved. There is a focus on ensuring the integration limits and variables are appropriately defined, with some confusion about the implications of the setup.
mikey555
A point charge +q is located a distance d from one end of a uniformly charged rod. The rod has total charge +Q and length L. (The rod and the point charge are each held fixed in place.)
What is the force on the point charge due to the rod?​
[tex]F = \frac{k q Q}{r^2}[/tex] (Coulomb's Law)
This is a really conceptual sort of question that comes up all the time for me--a simple integration problem of getting a common variable and then integrating. It's the setup that I've never understood.
So here's what I think we're doing conceptually: we're applying Coulomb's law an infinite number of times to an infinite number of small charges on this line of charge and adding them together.
If [tex]F = \frac{k q Q}{r^2}[/tex],
then [tex]dF = \frac{k q dQ}{r^2}[/tex], where [tex]dQ = Q (\frac{dl}{L}) = \frac {Q}{L} dl = \lambda dl[/tex]
(to find dF, we let dQ be an infinitely small charge and dF will be its infinite contribution. to find dQ, we take the infinite length that this charge possesses, dl, and take the percentage of the entire line that dl takes up. dl / L is like an infinite percentage that we multiply by Q to get dQ.)
So we have:
[tex]F = \int \frac{k q dQ}{r^2} = \int \frac{k q Q dl}{L r^2}.[/tex]
Here's where I have trouble. r is obviously changing for each charge, so I can't just pull it out of the integral. How to I write r, the distance from the point charge to each dQ, in terms of dl, an infinite length of the line, so that I can integrate?
More generally, how should I go about setting up integrals like this? I'm never sure if I should integrate dl and convert r, or integrate dr and convert dl. Does anyone have any tips on how to think about this?
mikey555 said:
… Here's where I have trouble. r is obviously changing for each charge, so I can't just pull it out of the integral. How to I write r, the distance from the point charge to each dQ, in terms of dl, an infinite length of the line, so that I can integrate?
Hi mikey555! :smile:
(btw, I'd always use x rather than l, because it's easier to write and to read :wink:)
Your difficulty is that you're using dl, but not l itself.
That's the tail without the dog!
GENERAL RULE:
Your proof (or your thought process) should begin, not with "consider an infinitesimal length dl", but "consider an infinitesimal length from l to (l + dl)".
Then you can immediately see that l goes from 0 to L (which gives you your limits of integration), and r = |d - l|. :smile:
If the point charge were at the end of the rod, then r and l would be the same. It isn't, so r is double-valued over the length 2d … you need a single-valued parameter to integrate over, so it needs to be l, not r. :wink:
Thanks for the fast response.
What does double-valued mean? Where does 2d come from (I thought we were only dealing with the length d!)?
I think what you said could really help but I don't understand it! If you could rephrase what I quoted above, it would be really helpful.
I meant that r is measured from that point d from the end, so for values of r less than d, there's two sections at distance r, one on the right and one on the left (but for r > d, there's only one section).
So if you integrated over r, you'd have to integrate from r = 0 to r = d, and then start again and integrate over r = 0 to r = L-d (unless you're willing to have negative values of r, which really doesn't appeal to me), but if you integrate over l, measured from the end of the rod, then l goes from 0 to L.
