Top High Torque Low Pressure Steam Power Generators for 1kW Output
The discussion revolves around finding a suitable engine, turbine, or expander capable of generating up to 1 kW of power output under low pressure (2 bar or 30 PSI). Participants explore various options, including steam power generation, and consider the feasibility and efficiency of different engine types for small-scale applications, particularly in rural settings.
  • Experimental/applied
  • One participant inquires about suitable engines or turbines for low-pressure steam generation and mentions the possibility of using a Tesla turbine.
  • Another participant suggests that developing 1 kW may not be cost-effective compared to purchasing electricity from suppliers.
  • A participant notes that a piston-driven engine would likely be necessary and emphasizes the importance of superheating steam for efficiency at low pressures.
  • One participant expresses a desire to develop a small-scale 1 kW system for rural areas and mentions the potential for future larger-scale implementations.
  • Another participant asks for clarification on the type of engine being considered.
  • Stirling engines are suggested as a possible option, although one participant finds it challenging to find one that meets their specifications.
  • A participant queries the source of steam for the project, to which another responds that it will come from an evacuated vacuum solar panel in a closed thermosiphon circuit.
  • There is a suggestion to consider an atmospheric engine due to the need for steady speed in electricity generation.
  • One participant mentions a project idea involving a Brayton cycle as a potentially cost-effective and safe option.
Participants express a range of views on the feasibility and efficiency of different engine types for low-pressure steam generation. There is no consensus on the best approach or specific engine model, and several competing ideas are presented.
Participants discuss various assumptions regarding efficiency, cost-effectiveness, and the practicality of different engine types under specific conditions. The conversation reflects a variety of perspectives on the challenges of low-pressure steam power generation.
This discussion may be of interest to individuals exploring small-scale power generation solutions, particularly in rural settings, as well as those researching steam engines and alternative energy systems.
mickeyt500
Does anyone know a suitable engine / turbine / expander that can run under 2 bar (30 PSI) of pressure and generate upto 1 kw power output? Basically a high torque, low pressure...i have been searching like crazy everywhere, cannot find anything...Also will a manufactured tesla turbine be able to do this? I have access to a mechanical workshop, but if this product is readily available off the shelf it would be nice. Or if any of u guys know of any mods to compressors or anything please share your ideas...
Thank u all
If you are only going to develop 1KW it probably is not worth while the capital outlay will buy you a great many KW-Hrs from your local electricity supplier.
It would need to be piston driven and fairly large. If you are using steam to drive it, do you realize that at that low presure you have very low efficiency? The power from steam comes from the superheat not from vaporizing the water. The more superheat you put in the greater the efficiency.
im trying to develop a 1 kW on small scale , trying to make it usable in rural areas...where 1 kW does wonders, future large scale implements will b worked on :) what do u guys think about a reciprocating tesla engine?
chayved buddy, what kind of engine do u have in mind?
Have you looked into Stirling engines?
yes buddy, but getting one that fits my specs is tedious
Where will you be getting the steam from?
I am going to be getting it from an evacuated vacuum solar panel in a closed thermosiphon circuit, using a heat exchanger.
As you are trying to generate electricity I guess that you need a fairly steady speed, otherwise have you considered an atmospheric engine?
I currently am thinking about a project using a brayton cycle. Seems to be the cheapest/safest option.
  • · Replies 47 ·
16K
