Can you use derivatives and integrals to solve algebraic problems?
The discussion revolves around the use of derivatives and integrals in solving algebraic problems, particularly the conditions under which differentiating both sides of an equation maintains equality.
  • Participants explore the validity of differentiating both sides of an equation, questioning when this practice holds true. There is a specific inquiry about the example of the equation x^2 = 4 and its implications.
The discussion is active, with participants providing insights and examples. Some clarify that derivatives of functions that are not identically equal may not yield valid results, while others reference specific cases where derivatives are applicable, such as in summation contexts.
There are references to specific mathematical examples and a link to an external image, indicating that some participants are drawing from textbook material or prior knowledge. The discussion includes a mix of conditional and identically equal functions.
Rib5
I've seen derivatives and integrals used before to change the form of an equation to one that is more suitable for solving a problem. Usually the person will just differentiate both sides and the equality holds? Is this always the case?
Because if you take the derivative of both sides of x^2 = 4, you get 2x = 0, which is not right. Can someone explain how this works?
I am not aware that you can do such things, do you have an example of where this was used?
But yes the equality will hold once you do the same thing on both sides of the equation.
What you have found in your example is the value of x for which x^2 - 4 has a horizontal tangent.
What you might be thinking of is that if two functions are identically equal (equal for all values of x), then their deriviatives are equal. In your example, the functions x^2 and 4 (or x^2 - 4 and 0) are not identically equal; they are only conditionally equal.
In my book they do use the derivative to solve an infinite sum.
http://img268.imageshack.us/img268/6097/probf.gif
[edit] Ah ok! Thanks!
This summation is identically true for all values of alpha, so the derivatives will also be equal.
[tex]\sum_{i = m}^n \alpha^i~=~\frac{\alpha^m - \alpha^{n + 1}}{1 - \alpha}[/tex]
  • · Replies 22 ·
