Explain the Cause of Spin in Billiards
  • Context: High School
  • Thread starter Thread starter IMMSHARMA
    Cause Spin
The discussion revolves around the causes of spin in billiard balls and whether this phenomenon is related to the spin of celestial bodies. Participants explore both mechanical explanations and the role of mental processes in achieving spin and direction in billiards.
  • Some participants propose that the spin of a billiard ball is caused by applying force off-center, creating torque around the center of gravity.
  • Others argue that even a centered impulse can lead to spin due to frictional forces acting on the ball after it slides.
  • A participant questions the necessity of mental involvement in producing spin, suggesting that a specific mental process is required to achieve the desired spin and direction.
  • Another participant challenges the idea that mental processes are the primary cause of spin, questioning how spin could exist before the evolution of minds.
  • Some contributions suggest a connection between the mechanics of billiard ball spin and the spin of celestial bodies, noting that both may arise from similar physical principles.
  • A participant introduces a theory involving Newton's third law and the triangle inequality theorem as a framework for understanding spin, though this is met with skepticism regarding its validity.
  • There are claims that a specific mental routine is necessary for executing shots in billiards, with implications that this could challenge existing mechanical explanations.
Participants express differing views on the role of mental processes versus mechanical explanations in producing spin. There is no consensus on whether mental involvement is essential or if spin can be fully explained through physical interactions alone.
Some arguments rely on assumptions about the nature of mental processes and their impact on physical outcomes, which remain unresolved. The discussion also touches on philosophical implications regarding the existence of a mind behind celestial phenomena.
IMMSHARMA
Can anyone here explain me as to what causes the spin of a billiard ball and is this 'spin of a ball', in any way, related to the spin of the 'celestial balls'?
Well the spin of the billiard ball is caused by the force being applied in a way that does not put the direction of the impulse through the center of gravity of the ball, thus applying a torque around said center of gravity.
Not necessarily; if a centered impulse causes the ball to slide, the frictional force from the ground in the aftermath will provide a torque.
Eventually, the ball will go into "pure rotation", i.e, the contact point velocity on the ball is zero.
(On second thought, read differently, your answer covers this aspect as well..)
Does it mean that no involvement of our mind(apart from 'physical' hitting the ball) is necessary to produce a spin motion in the ball and also make it take the intended direction before it strikes the object ball?If mental involvment is necessary,what sort of calculation is to be done mentally so that two things(spin in the ball and the required direction) are achieved without fail?Please let me know if physics has any concrete answer to the question in the contest.
I'm not sure what you are asking here about "mental involvement". Assuming the ball starts at rest, what makes it spin (as has been explained) is a net torque about its center of mass; what makes the ball accelerate is a net force. The degree of "mental involvement" required depends upon your skill in billiards, I presume. :smile:
Do a web search on the physics of pool or billiards and you will find lots of interesting discussion on this topic.
(Please don't post the same question in multiple forums, or multiple times in the same forum.)
My reference to the required 'mental involvement' takes it's source in the 'strange out come ' of my years of research on the subject of 'aiming'...The strange result is that human mind(irrespective of age,sex etc.,) does require to complete a simple (seemingly... but complex in depth) routine-a 'mental process',along the line of aim, before we strike the ball to produce a spin motion in it and more amazing is that the 'routine' is to be applied(mental completion) in the opposite (back ward) direction of the line of aim in order to get a 'spin stroke' and that if the same routine is applied along line in the same forward direction to get a 'spin less stroke'.
Also...the results show that it's just impossible to produce the 'spin motion' in the required direction without the specific 'routine' (mental process) duely completed by the mind.
Thus,apart from mechanical explanations of cause of spin,I feel,it can be proved that a specific mental process i.e the mind is the real cause of spin.
And as for 'celestial spin',it's known to all that one of the very fundamental questions of cosmology,the cause of spin of the 'celestial balls'-the erath and the other bodies,still remains unanswered(satisfactorily) by modern science.The question has been set aside with some 'vague' explanation...
So...based on my research results,it could be convincingly proved that a ball (terrestial or celestial) DOES require a MIND at work with a SPECIFIC process.Then it's not hard to imagine whose MIND is behind the spin of the earth...in other words..doesn't this conclusion lead to the proof of 'Existence Of God' ? and is it not for us to conclude (philosophically) what's true is "mind over matter"?
Hope I made my point clear.
Yes; as far as you are able to..
Unfortunately, your feelings on the subject are not enough. What possible reason could one have for supposing that things did not spin before minds evolved?
What he is saying is God made the celestral bodies spin, cause we were not here and we make pool balls spin cause we invented them. :surprise:
Spin.
A plane + Triangle inequality theorem = spin.
Suppose I could, with the help of my 'discovery', change a 'novice' into a 'champion' (i am ready to take up the challenge) relatively in a short span of time,or if I could make the masters of the game accept the truth of my theory... ?Woudn't it be the best proof of my theory? Then,wouldn't all the mechanical explanations (the very 'motion' related explanations) given by physics(modern science) stand disproved?
Newton's third law.
This person is applying Newton's third law.
Goes like this.
Newton's third law < Newton's third law + Newton's third law
Triangle inequality theorem.
This is his spin formula.
(c)Action < (a) Reaction + (b) Reaction,
(a)Reaction < (b) Reaction + (a) Action,
(b) Reaction < (a) Reaction + (c) Action.
Now the idea present in the Triangle inequality theorem above is that there are plural points(a), (b), (c). Plural, not singular. Less < Greater = Plural.
My proff is. Can Newton's third law agree with the Triangle inequality theorem ? Of course it does. Right ? :smile:
So there you be. The spin this person is mentioning. Present from none other than action. We equal action. So...where does this conclusion lead too ? God perhaps ?
A billiard ball spins because of the friction of the table and the difficulty of hitting the ball exactly perpendicular to dead center. Likewise, almost every celestial object displays spin for similar reasons. What is more, objects such as the Earth are not nearly as solid as a billiard ball. Their internal constituents are constantly in motion, just as the atoms in your body are constantly in motion, sometimes at relatively high speeds. All of these influences, both internal and external, tend to impart spin.
yeah, nice theory... let's try it out...
i'm going to convince my girlfriend that you don't exist, and then you tell me whether or not you dissapear, okay?
Goes like this.
This is his spin formula......"
You are mistaken...No Newton's law..nothing..It's unique...like a geometric figure "routine" to be completed(clicked mentally) along the path of the ball at each and every stroke and without which no 'spin stroke' is produced!
Let me make my point more clear...
Using a cue any player can produce two types (a plain 'spin less and 'spin stroke' ) while making a shot...but what he requires is to set the cue ball into anyone of these two types of motion in the REQUIRED LINE to make the object ball getting pocketed.
It's exactly here,while hitting the ball,his mind requires to get into action and completes a 'specific routine'(the concerned mental process).If he hits without the mental routine (common to all types of shots) the cue ball NEVER takes the intended path ! This 'routine ' completion takes place without his actual knowledge.Just ,he learns through practice,to get USED to hit the ball exactly when the mind has completed the routine...he does it just by FEEL...
Now...my discovery is that what exactly this mental process (the routine) is and how it works.Is it not an exploration of the miracles or the secrets of mind to which even modern science has no access yet?I mean my discovery trasforms a 'thing of feel' into a 'thing of concrete knowledge' Isn't it a miracle? !
Also...Physical part of aiming is just limited to searching for the aim point (actually a player never gets it,while sroking...he pretends to be concentrating on it for the fear of miss) or trying to get a vague 'un seeable' line of aim...etc.But what plays the entire role is totally MENTAL...
A player HAS to stroke(hitting of cb) only AS AND WHEN a particular 'routine' is completed mentally ! Of course different players apply it (the same routine) in different ways...yes,there are different modes of applying it and most probably this must be the reason why we have different styles of stroking like fast,slow,care free etc...
And WITHOUT this mental routine completion it's simply IMPOSSIBLE (for any human being..even for a champion of the game) to send the ball in the intended line !It's like getting oil from sand !(provable)...
Also...after some acuaintance of this 'true knowledge of the stroke',we actually need not worry about the aim point or line of aim...mind does it...(getting the line and completing the routine),in just fraction of a second,independent ot of our willing ness...whenever you get to deliver your stroke !(any body..even a ten year old,can be taught or made to grasp it)
Even more,contrary to our mechanical conceptions like conc. on aim point,(focus) visually... etc...,we CAN execute the shot( with equal success)with our eyes CLOSED too...depending only on the 'mental routine' !(provable)
As for the type of shot,the same 'mental routine' works...to be applied in the forward direction (for spin less stroke) and in the back ward direction (for spin stroke)['why back ward' can be explained ...]
Hope I made the whole thing clear.
where did you even get this idea from anyway?
A lack of friction against the table? :wink:
Pool balls don't spin because we invented them. They spin due to unbalanced torques.
interpretation
You answered IMMSHARMA
So he needs your answer not me, You are both thinking on different wavelengths, I am just pointing out which one he is on. In answer to your answer, I would agree and no spin is a 8 ball stait in the pocket. :smile:
  • · Replies 32 ·
  • · Replies 27 ·
