Metrics in Special Relativity & General Relativity
  • Context: Graduate
  • Thread starter Thread starter kurious
The discussion revolves around the nature and properties of metrics in special relativity and general relativity. Participants explore various questions regarding the existence, transformation, and implications of different metrics, as well as their relationship to physical phenomena such as black holes and curvature in spacetime.
  • One participant questions how many metrics exist in special and general relativity and whether one metric can be transformed into another.
  • Another participant clarifies that the metric tensor is a geometric object that defines magnitudes of vectors and cannot be changed by transformations, although its components can be.
  • There is a discussion about whether objects without spherical symmetry can have metrics, with a participant stating that metrics are associated with physical distributions of matter as per Einstein's Field Equations.
  • A question is raised about the possibility of two different manifolds intersecting with equal metrics, suggesting they would be the same manifold instead.
  • Participants discuss whether supermassive black holes have Schwarzschild metrics, with one suggesting that they likely have angular momentum and are better described by the Kerr metric.
  • Another participant inquires about the number of solutions to the Einstein Field Equations (EFE) and questions the uniformity of mass in curving spacetime.
  • There is a discussion on whether dark energy curves spacetime similarly to other energy sources.
  • One participant seeks clarification on whether the metric determines the curvature of a manifold and how the metric reflects changes in basis vectors across space.
  • Further technical details are provided regarding the relationship between the metric tensor, curvature, and the components of the connection in Riemannian geometry.
  • It is noted that while there are ten independent equations in the EFE, a complete characterization of all solutions has not been achieved.
Participants express differing views on the nature of metrics, their transformations, and the implications for physical phenomena, indicating that multiple competing perspectives remain without a clear consensus.
Some discussions involve assumptions about the nature of mass and energy in relation to spacetime curvature, as well as the definitions and properties of metrics and tensors, which may not be universally agreed upon.
kurious
How many metrics are there in special relativity and in general relativity?
Can one metric be transformed into another?
Can objects that don't have spherical symmetry have metrics?
Is it possible for two different manifolds to intersect and for their
metrics to be equal where they intersect?
Do supermassive black holes have Schwarzschild metrics?
If all the mass in the universe is at one point, space-time doesn't exist and nor does the concept of a metric.Do metrics become invalid at more normal mass-densities?
Are metrics conserved:if a black hole evaporates, does a new black hole appear elsewhere in the universe?
What sort of metric describes the space-time around a single proton?
If a graviton has energy that curves space-time, what would its metric be?
Do you mean metric or metric tensor? See
http://mathworld.wolfram.com/Metric.html
http://mathworld.wolfram.com/MetricTensor.html
re - " Can one metric be transformed into another?"
To be 100% precise, not really. The metric tensor is a geometric object which is defines the magnitudes of vectors. I.e. that means that its defined as a bilinear map of two vectors into a scalar. I.e. the metric tensor is defined as a "machine" g(_, _) such that when you insert two vectors it outputs a scalar (i.e. a single number which is independent of any coordinate system used to evaluate the number). It is defined such that when you put in a vector you get the squared length of the vector or if you put in two different vectors you get the scalar product of the two vectors. Since its a geometrical object it can't be changed by any transformation. What you can transform are the components of the metric tensor.
re - "Can objects that don't have spherical symmetry have metrics?"
An object does not have a metric tensor. In GR there is a one-to-one association between a physical distribution of matter and the spacetime in which that matter is in. That association is given by Einstein's Field Equations (EFE). There is a metric associated with each such spacetime. The metric defines the geometry of the spacetime and is a solution to the EFE. The geometry of the spacetime is defined when the infinitesimal spacetime interval is defined between all neighboring events. That interval is given by the metric tensor.
re - "Is it possible for two different manifolds to intersect and for their
metrics to be equal where they intersect?"
According to the definition of "manifold" they'd be the same manifold, not two different manifolds.
re - "Do supermassive black holes have Schwarzschild metrics?"
Its unlikely to happen in nature because its probable that all black holes have some angular momentum and as such are described by the Kerr metric and not the Schwarzschild metric.
Pete
PMB:
Kurious:
How many solutions are there to the EFE- I gather there are 16 EFE's.
Why can't EFEs be given solutions internal to a curvature generating mass?
And why would 1kg of hydrogen curve space-time the same as 1 kg of electrons or photons (I'm thinking here of the Eotvos experiment which showed that the nature of a mass was irrelevant to how it accelerated)?
Does dark energy curve space-time the same as other energy sources?
I understand the use of the metric tensor but is it the metric that determines the curvature of a manifold? And does the metric in GR reflect how the basis vectors change from one point in space to another?
kurious said:
PMB:
Kurious:
How many solutions are there to the EFE- I gather there are ten EFE's.
In Riemannian geometry, or the pseudo-Riemannian geometry in General Relativity, this is true. The components of the connection are then the Christoffel symbols, differential expressions of the components of the metric tensor with respect to the spactime coordinates. And a linear combination of these expressions constitutes the Riemann-Christoffel tensor, which is the complete description of the local curvature of spacetime; so that all comes straight out of the metric in this type of geometry. Einstein's tensor, the left side of his field equations, is formed by "contracting" the Riemann-Christoffel tensor, so again the left side of the equation is a differential expression based on the metric coefficients.
Because the field equation is between second rank tensors in four dimensions, the naive number of component-by-component equations would be 4x4=16. But the tensors are symmetric, so that six of the equations are the same as another six, leaving only ten independent component-by-component equations.
AFAIK, nobody has every done a complete characterization of the family of solutions of Einstein's equations. What we have instead is just a growing number of particular solutions, of which the Schwartzschild solution was the first.
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 45 ·
