Solving Schrodinger's Equation: Finite Jumps at Singular Points?
  • Context: Graduate
  • Thread starter Thread starter RedX
    Schrödinger
This discussion addresses the behavior of solutions to Schrödinger's equation, particularly when encountering singular points where the potential V approaches infinity. It establishes that while the second derivative of the wave function ψ can become infinite, this does not guarantee a finite jump in the first derivative dψ/dx at those points. The analysis emphasizes that the assumption of a finite jump is invalid if the wave function ψ approaches zero, as demonstrated in the case of the infinite potential well, where ψ is zero at the boundaries despite having a finite slope jump.
  • Understanding of Schrödinger's equation and its components
  • Familiarity with differential equations and their solutions
  • Knowledge of singular points in mathematical functions
  • Concept of wave functions in quantum mechanics
  • Study the implications of singularities in differential equations
  • Explore the properties of wave functions in quantum mechanics
  • Learn about boundary conditions in quantum systems, particularly the infinite potential well
  • Investigate the mathematical treatment of discontinuities in solutions to differential equations
Quantum physicists, mathematicians specializing in differential equations, and students studying quantum mechanics who seek a deeper understanding of wave function behavior at singular points.
RedX
When solving Schrödinger's eqn. one comes across the expression:
[tex]\frac{d^2 \psi}{dx^2}=(V-E)\psi[/tex]
where the mass has been chosen to make [tex]\frac{\hbar^2}{2m}=1[/tex]
If V is infinity at some x, then it is said that [tex]\frac{d \psi}{dx}[/tex] can have a finite jump at that x, since [tex]\frac{d^2 \psi}{dx^2}=\infty[/tex]
But doesn't this assume that [tex]\psi[/tex] doesn't go to zero? Then you would get: [tex]\frac{d^2 \psi}{dx^2}=(V-E)\psi=\infty*0[/tex] and it is not necessarily true that [tex]\frac{d^2 \psi}{dx^2}=\infty[/tex], hence no longer necessarily true that [tex]\frac{d \psi}{dx}[/tex] can have a finite jump.
The easiest case is the infinite well. The solution at the boundary of the well does have a finite jump in its slope. However, the function [tex]\psi[/tex] itself is zero at the boundaries of the well.
So in general, if you have a differential equation [tex]y'=f(x)y[/tex], where f(x) is singular at a point [tex]x_0[/tex], can you assume a finite jump in the solution y at [tex]x=x_0[/tex]?
No, you cannot assume a finite jump in the solution y at x=x_0. This is because the equation y'=f(x)y only holds if both y and f(x) are non-zero. If f(x) is singular at x_0, then it is not necessarily true that y will have a finite jump at x_0.
  • · Replies 21 ·
  • · Replies 17 ·
  • · Replies 59 ·
  • · Replies 32 ·
