What is the angle of a falling object's velocity after 2 seconds?
The problem involves a stone thrown from a cliff at a speed of 30 m/s at an angle of 0 degrees. Participants are discussing how to determine the angle of the stone's velocity after 2 seconds, specifically with respect to the horizontal direction.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants are attempting to calculate the vertical component of velocity (Vy) after 2 seconds, questioning the initial vertical velocity (Vyo) and its implications on the angle calculation. There is discussion about the use of tangent and inverse tangent functions in determining the angle.
Some participants have provided calculations and expressed uncertainty about the correct approach to finding the angle. There is a recognition that both Vy and the resulting angle should be negative, and some guidance has been offered regarding the use of inverse tangent.
Participants are working under the assumption that the stone is thrown horizontally, and there is a focus on the effects of gravity on the vertical component of velocity. The discussion reflects confusion over the initial conditions and the appropriate mathematical methods to apply.
yankees26an
A stone is thrown off a high cliff with speed 30m/s at an angle 0 degrees. At what angle is the stone's velocity 2 seconds after it's thrown. (measired with respect to the horizontal x direction(angle will be negative))
angle = tan(Vy/Vx)
V = velocity
Vx = stays constant = 30m/s
Vy = Vyo + ay*t = 30 m/s + 19.6 m/s = 49.6 m/s
angle = tan(49.6/30) which is wrong
What's Vyo equal to?
Then I guess it would be 0 m/s?
If it was 0 then I would have Vy = 19.6 and then
tan(19.6/30) is still not the right answer
Seems right to me. Don't forget that Vy and thus the angle are both negative.
tan((-19.6) / 30) = -0.765477483
The correct answer(supposedly) is -33.2 degrees with respect to the horizontal +x direction.
That should be inverse tan, not tan. tanθ = (-19.6/30) → θ = tan-1(-19.6/30). (I misread what you wrote before. :rolleyes:)
  • · Replies 38 ·
