How Do You Calculate the Kinetics of a Suspended, Unwrapping Cylinder?
  • Thread starter Thread starter GleefulNihilism
    Cylinder Kinetics
This discussion focuses on calculating the kinetics of a suspended, unwrapping cylinder, specifically addressing linear momentum, angular momentum, and kinetic energy. The linear momentum is derived using the equation P = (m/2)*(x'^2 + y'^2), where x' and y' are expressed in terms of the variables l, phi, l', and phi'. The angular momentum is calculated using M = I*omega, with the moment of inertia I for a uniform cylinder defined as I = (mr^2)/2. Finally, the kinetic energy T is formulated as T = (P^2)/2m + (M^2)/2mr^2, leading to a comprehensive expression for T in terms of the relevant variables.
  • Understanding of linear momentum and angular momentum concepts
  • Familiarity with moment of inertia calculations for rigid bodies
  • Knowledge of kinetic energy equations in classical mechanics
  • Proficiency in calculus for differentiating and manipulating equations
  • Study the derivation of the equations for linear momentum in rotational systems
  • Explore advanced topics in rotational dynamics, focusing on the effects of tension in strings
  • Learn about the conservation of energy principles in oscillating systems
  • Investigate the application of Lagrangian mechanics to similar problems
Students in physics or engineering disciplines, particularly those studying dynamics and mechanics, as well as educators seeking to enhance their understanding of rotational motion and energy conservation principles.
GleefulNihilism
Well, I had a couple problems on my final I was hoping to go over- hope nobody minds. Here's the first.
A uniform cylinder of radius r and mass m, wrapped around by an unstretchable and massless string, is suspended from a point. The cylinder comes down unwrapping the string and oscillating around the horizontal axis passing through the point under the action of gravity. Let l be the distance from the support point to the contact point of the string with the cylinder and phi be the angle the string forms with the vertical axis through the support point.
Find:
a.) The magnitude of the linear momentum of the cylinder.
b.) The angular momentum of the cylinder.
c.) The kinetic energy of the cylinder in terms of l, phi, dl/dt (written as l'), and d(phi)/dt (written as phi').
(Sorry, not sure how you do the fancier presentation codes.)
Linear Momentum
P = (m/2)*(x'^2+y'^2)
Angular Momentum
M = I*omega
Moment of Inertia for a Uniform Cylinder
I = (mr^2)/2
Kinetic Energy
First, was part A.
The trick being finding x'^2 and y'^2. Preferably in terms of l, l', phi, and phi'.
Let's call the angle from the contact point on the cylinder to the center of the cylinder theta. Distance between these two points is always r- which is a constant in this problem. Woot!
So, x = l*sin(phi) + r*cos(theta) and y = l*cos(phi) + r*sin(theta).
Now, admittedly my weakest assumption, I assumed that the angle formed by the string to the contact point to the center of mass of the cylinder was usually around 90 degrees. Especially if the string wasn't close to being completely unwound. So, by method of similar triangles phi is about equal to theta.
Thus, roughly, x = l*sin(phi) + r*cos(phi) and y = l*cos(phi) + r*sin(phi).
Therefore x' = d(l*sin(phi) + r*cos(phi))/dt = l'*sin(phi) + l*phi'*cos(phi) - r*phi'*sin(phi)
Thus x'^2 = (l'*sin(phi) + l*phi'*cos(phi) - r*phi'*sin(phi))^2
And by similar arguments y'^2 = (l'*cos(phi) - l*phi'*sin(phi) + r*phi'*cos(phi))^2
So P = (m/2)*(x'^2 + y'^2)
P = (m/2)*((l'*sin(phi) + l*phi'*cos(phi) - r*phi'*sin(phi))^2 + (l'*cos(phi) - l*phi'*sin(phi) + r*phi'*cos(phi))^2)
Which expands into something that on the surface looks rather messy, but a few terms add out and other terms are simplified by the good old cos^2(theta) + sin^2(theta) = 1 identity.
So P = (m/2)*(l'^2 + l^2*phi'^2 + r^2*phi'^2 + 2*r*l'*phi'(cos^2(phi) - sin^2(phi)) - 4*r*l*phi'^2*sin(phi)*cos(phi))
B.
M=I*omega
For a uniform cylinder I = (mr^2)/2. Also known is omega = (v/r) = (P/mr)
Thus M = P*(r/2)
C.
Which when you plug in P and M, do a little multiplication by constants, and you get.
T = (5m/32)*(l'^2 + l^2*phi'^2 + r^2*phi'^2 + 2*r*l'*phi'(cos^2(phi) - sin^2(phi)) - 4*r*l*phi'^2*sin(phi)*cos(phi))^2
No bites, eh?
Well, if it helps I don't need to be taken by the hand. I just want to see how the professor got these answers.
A) P = m*sprt((l'-r*phi')^2 + l^2*phi'^2)
B.) M = (3/2)*m*r*(l' - r*phi')
C.) T = (3/4)*m*(l'-r*phi')^2 + (m/2)*l^2*phi'^2
  • · Replies 46 ·
10K
