Product of two consecutive integers
  • Thread starter Thread starter nobahar
    Integers Product
The discussion revolves around proving that the expression n^2+n is even for positive integers n. Participants explore various approaches to this problem, including algebraic manipulation and induction.
  • Participants discuss the factorization of n^2+n and its implications regarding evenness. Some question the necessity of induction, while others provide alternative proofs based on cases for even and odd integers.
The conversation includes multiple perspectives on the proof, with some participants affirming the simplicity of the original approach. There is an ongoing exploration of different methods, including direct reasoning and induction, without reaching a consensus on the preferred method.
Some participants note the importance of considering both cases for n being even or odd, highlighting potential assumptions in reasoning. The discussion reflects a learning environment where participants are encouraged to clarify their understanding of the problem.
nobahar
Prove that [tex]n^2+n[/tex] is even. Where n is a positive integer.
[tex]n^2+n[/tex]
[tex]n^2+n = n(n+1)[/tex]
One of which must be even, and therefore the product of 2 and an integer k.
[tex]n = 2k, \left \left 2*(k(n+1))[/tex]
or
[tex]n+1 = 2k, \left \left 2*(n*k)[/tex]
Is there a better way of doing this? I read this is not an inductive proof; what would this entail?
Many thanks in advance.
This looks absolutely fine. No need for induction at all.
As rochfor1 said, that is a perfectly good proof and simpler than "proof by induction".
But since you ask, here goes:
If n= 1, then [itex]n^2+ n= 1^2+ 1= 2[/itex] which is even.
Now, suppose that [itex]k^2+ k[/itex] is even and look at [itex](k+1)^2+ (k+1)[/itex]
[itex](k+1)^2+ (k+1)= k^2+ 2k+ 1+ k+ 1[/itex][itex]= (k^2+ 2k)+ 2k+ 2[/itex]. By the induction hypothesis, [itex]k^2+ k[/itex] is even and so [itex]k^2+ k= 2m[/itex] for some integer m (that is the definition of "even") so [itex](k+1)^2+ (k+1)= (k^2+ 2k)+ 2k+ 2[/itex][itex]= 2m+ 2k+ 2= 2(m+k+1)[/itex]. Since that is "2 times an integer", it is even.
Having proved that the statement is true for 1 and that "if it is true for k, it is true for k+1", by induction, it is true for all positive integers.
Yet a third way: If n is a positive integer, it is either even or odd.
case 1: n is even. Then n= 2m for some integer m. [itex]n^2= 4m^2[/itex] so [itex]n^2+ n= 4m^2+ 2m= 2(m^2+ m)[/itex]. Since that is 2 times an integer, it is even.
case 2: n is odd. Then n= 2m+ 1 for some integer m. [itex]n^2= (2m+1)^2= 4m^2+ 4m+ 1[/itex] so [itex]n^2+ n= 4m^2+ 4m+ 1+ 2m+ 1[/itex][itex]= 4m^2+ 6m+ 2= 2(2m^2+ 3m+ 1)[/itex]. Again that is 2 times an integer and so is even.
Many thanks rochfor1 and HallsofIvy!
Simple reasoning is needed.
For two consecutive integer , one will be even and another will be odd.
Thus;
[tex]n\equiv0(mod 2)[/tex]
and
[tex]n+1\equiv1(mod 2)[/tex]
We may now conclude that [tex]n(n+1)\equiv0(mod 2)[/tex] and means that n²+n is even.
If n is odd, n^2 is odd. If n is even, n^2 is even. odd+odd=even and even+even=even.
OP: Why do you want a proof by induction? The proof you gave is simple and beautiful.
What you say is true, but you can't ascertain which of them will be even and which will be odd. In what follows, you are assuming that n is even and n+1 is odd. That is one of two possible cases, so you work is not complete.
icystrike said:
Thus;
and
yes that is true. for the other case , it can be proved analogously .
  • · Replies 49 ·
