Could I Have Americium in My Blood Stream After Handling a Smoke Alarm?
  • Context: Medical
  • Thread starter Thread starter Collserra
    Blood Stream
The discussion centers on the safety concerns regarding potential americium contamination after handling a smoke alarm. The user expressed anxiety about having americium-241 in their bloodstream following a minor injury while disassembling the device. Experts clarified that the likelihood of contamination is extremely low, as americium is contained within a small metal disk and primarily emits alpha radiation, which is not easily detected by standard Geiger counters. The consensus is that if the user did not directly disturb the americium source, there is no cause for concern.
  • Understanding of alpha radiation and its properties
  • Familiarity with Geiger counters and their detection capabilities
  • Knowledge of americium-241 and its use in smoke detectors
  • Basic first aid for minor injuries
  • Research the properties of americium-241 and its health effects
  • Learn about Geiger counter calibration and limitations in detecting alpha particles
  • Explore safety protocols for handling radioactive materials
  • Investigate the disposal and recycling processes for smoke detectors
This discussion is beneficial for individuals interested in radiation safety, hobbyists working with Geiger counters, and professionals involved in hazardous material handling, particularly those dealing with smoke detectors containing americium-241.
Collserra
Okay so I just got my new geiger counter from ebay and was taking apart an old smoke alarm to get the americium out to test it with. I was cutting away the metal housing when all of a sudden their was a snap, the cutters had bent the metal around and it had cut me. I am very scared now that the housing might have have induced radioactivity in it or that it had minute particles of americium on it that are now in my bloodstream. Does anyone know if this might be true or if I am just overeacting to a minor incident. I measured the cut with my geiger counter and it read 0. But I just can't shake the feeling that I might have americium or radioactive housing in my bloodstream right now.
Biology news on Phys.org
There is a microgram sample of Am 241 in smoke detector and is housed inside a small metal disk structure. It's very unlikely that you have it on you. If you touched the metal structure with pliers and then you cut yourself, then nothing to worry about, but if you poked the center of the disk with pliers and then cut yourself, then the worst case scenario is you have a few atoms on you and will likely urinate them out of your system. Also Am 241 is pretty much an alpha emitter which is very weak, and many Geiger counters are not deigned to pick up alpha radiation, so that's why you might not be picking anything up, except beta from other decay products.
  • · Replies 21 ·
  • · Replies 41 ·
9K
  • · Replies 42 ·
