Double Integration Check: Evaluating a Double Integral for a Triangle
  • Thread starter Thread starter tomeatworld
    Integration
The discussion focuses on evaluating the double integral \(\int\int (x^{2}(y+1) + e^{y})\) over a triangular region defined by the vertices (0,0), (1,1), and (-1,1). The correct limits of integration for this triangle are established as x = -y to x = y for the inner integral, and y = 0 to y = 1 for the outer integral. The participant emphasizes the importance of understanding the geometric representation of the triangle to derive the appropriate limits, rather than relying on integrating a square region.
  • Understanding of double integrals in calculus
  • Familiarity with triangular regions in coordinate geometry
  • Knowledge of integration techniques with respect to multiple variables
  • Ability to visualize geometric shapes in the Cartesian plane
  • Study the concept of double integrals over non-rectangular regions
  • Learn about changing the order of integration in double integrals
  • Explore applications of double integrals in physics and engineering
  • Investigate the use of Jacobians in transforming variables for integration
Students and educators in calculus, mathematicians focusing on integration techniques, and anyone interested in applying double integrals to geometric problems.
tomeatworld
More of a check
Evaluate [tex]\int\int (x^{2}(y+1) + e^{y})[/tex] for a triangle with vertices at (0,0) (1,1) (-1,1)
Integration
The only this I wanted to check, is that integrating the square at y=0 to 1 and x=0 to 1 will give the correct answer (as the triangle is reflected on the y axis) and if not, how you get the limits.
I don't see how "integrating the square at y = 0 to 1 and x = 0 to 1" relates to this problem, even if it happens to produce the right answer.
If you integrate first with respect to x and then with respect to y, your limits of integration will be x = - y to x = y, and then y = 0 to y = 1.
  • · Replies 19 ·
  • · Replies 17 ·
