Show arctan(y/x) satisfies Laplace's equation
  • Thread starter Thread starter alex3
    Laplace's equation
The discussion revolves around demonstrating that the function arctan(y/x) satisfies Laplace's equation. Participants explore the necessary partial derivatives and the implications of using different forms of the function, such as arctan(x/y).
  • Participants discuss the calculation of second derivatives and the challenges involved, including the use of product and chain rules. There are questions about the correctness of derivatives and the implications of different variable arrangements.
The discussion is active, with participants providing insights and corrections regarding derivative calculations. Some suggest alternative methods, such as using spherical coordinates, while others express uncertainty about the implications of their findings.
There is mention of confusion regarding the function forms (arctan(y/x) vs. arctan(x/y)) and the impact this has on the derivatives. Participants also note their varying levels of familiarity with complex numbers and analytic functions, which may affect their understanding of the problem.
alex3
Show that arctan(y/x) satisfies Laplace's equation.
Laplace's equation:
[tex]\frac{\partial^{2}f}{\partial x^{2}}+\frac{\partial^{2}f}{\partial y^{2}}=0[/tex]
We haven't really done this is class too thoroughly, I've looked a http://www.wolframalpha.com/input/?i=second+derivative+of+arctan(y/x)" and it looks pretty messy, and I get the feeling I missing something. I have done partial derivatives, and we've done an exercise in class where we've transformed cartesian to polar co-ords, but I can't see the connection.
Thanks for any help.
alex3 said:
Show that arctan(x/y) satisfies Laplace's equation.
Laplace's equation:
It is never messy. Actually its second derivative with respect to x is [tex]-2\,x{y}^{-3} \left( 1+{\frac {{x}^{2}}{{y}^{2}}} \right) ^{-2}[/tex]. So I think you better put all your energy into finding its derivative wrt y. There you'll be left with some addition\subtraction(s) to put an end to this challenge!
AB
Aha, I've noticed I made a mistake and made a reference to arctan(x/y) rather than arctan(y/x), which is the problem. Does this change things?
Am I right in saying then that I need to find those double partial derivatives and then find the sum (and hope I get zero)? That's 'all' there is to the question?
It makes no difference. In both cases you'll hit the answer 'zero'. That online integrator probably assumes y as a function of x and then this makes the first and second derivatives of f look enormously immense as the derivatives of y wrt x are to be involved as well.
If y is a function of x, I have a really simple solution for that which also applies to this one, too. And you talked about it in your first post... :)
I'm having problems with the second derivative, I'm using the product rule like so
[tex] \frac{\partial}{\partial x} \left( \frac{y}{x^{2}} \times \frac{1}{\frac{y^{2}}{x^{2}} + 1}\right)[/tex]
And getting a pretty nasty result. I don't mean to question the help, but are you sure that's the second derivative?
The derivative of arctanu(x) is [tex]u'(x)/(1+u^2)[/tex]. From this rule, you must get for u=x/y, [tex][arctanu(x/y)]'= (1/y)/(1+(x/y)^2)[/tex]. This is totally different from what you have given us and of course yours sounds so cumbersome to go on with and above all else it's incorrect. Taking another derivative of f wrt x simply gives [tex]-(2x/y^2)(1/y)/[1+(x/y)^2]^2[/tex]. So isn't this the same as the one I gave earlier!? Check out your calculations again, but carefully, to find out where you went wrong with differentiation.
Another way to solve this problem is to use the spherical coordinates in place of Cartesian coordinates: Take [tex]\theta=arctan(x/y)[/tex] and then use the the chain rule to replace d/dx and d/dy by [tex]d/d\theta[/tex]. This will make calculations way easier than when you keep going with the traditional method.
AB
u=y/x, rather than x/y. I know you said this makes no difference, but the differential is different, surely? The first will become
[tex] -\frac{x^{-2}y}{1+\frac{y^{2}}{x^{2}}}[/tex]
Won't it? Apologies if I'm being frustrating, I really don't mean to be!
That's right so far. It looks like it gets messy, but it's really not that bad.
By the way, your second derivative won't match what Altabeh got because you're working on different terms since Altabeh started with arctan(x/y) and you started with arctan(y/x).
One line proof:
arctan(y/x) = Im[Log(z)] and we know that the real and imaginary parts of analytic functions satisfy the Laplace equation.
I'm afraid I'm not familiar with analytic functions, I've only very briefly touched on imaginary/complex numbers, and my knowledge of Laplace's equation extends only as far as the form it takes, rather than general rules about its satisfaction.
It certainly looks much nicer than the way I have to do it though! I managed to work it all out in the end mind; thanks to everyone who helped!
  • · Replies 18 ·
