Electric Field at a Distant Point
The discussion focuses on calculating the electric field at a distant point on the +x axis due to an electric dipole consisting of a positive charge q at (a,0) and a negative charge -q at (-a,0). The correct formula for the electric field is established as E(x) = 4kqa/x^3, derived from the principles of electric field calculations. Participants clarify the importance of using the correct distance values in the equations, specifically emphasizing the need to use x-a and x+a instead of x and x-2a for accurate results. Missteps in simplification and unit consistency are also highlighted as common pitfalls in the problem-solving process.
  • Understanding of electric dipoles and their configurations
  • Familiarity with Coulomb's Law and electric field equations
  • Knowledge of algebraic manipulation and simplification techniques
  • Basic calculus concepts, particularly limits and approximations
  • Study the derivation of electric fields from dipoles in "Introduction to Electrodynamics" by David J. Griffiths
  • Practice problems involving electric field calculations for various charge configurations
  • Learn about the implications of the dipole approximation in electrostatics
  • Explore the concept of electric field lines and their representation in different charge distributions
Physics students, educators, and anyone interested in mastering electrostatics and electric field calculations will benefit from this discussion.
davezhan
1. Consider the electric dipole on the x-axis where a positive charge q is at (a,0) and a negative charge -q is at (-a,0) such that the distance between the two charges is 2a. Show that the electric field at a distant point on the +x axis is
E(x)= 4kqa/x^3.
2. Homework Equations : E=kq1q2/r^2
3. The Attempt at a Solution :
E=kq/x^2 - kq/(x+2a)^2
E(simplified)=kq[x^-2 - (x^2+4a)^-1]
E=4kqa/(x^4+4x^2a)
This clearly gives me the wrong solution, but I know it works when I switch my r values.
Why is it that I have to use x-a and x+a for r instead of x and x-2a?
Why does shifting the y-axis change the answer since x>>2a, it shouldn't matter, but I'm getting a different solution using this approach.
Please help me understand this problem! Thanks!
E=4kqa/(x^4+4x^2a)
Check this simplification.
E = kq[1/x^2 - 1/(x + 2a)^2]
= kq[(x+2a)^2 - x^2]/(x)^2*(x+2a)^2
= kq[4ax+4a^2]/(x)^2*(x+2a)^2
= kq*4ax*(1+a/x)/(x)^4(1+2a/x)^2
Neglect a/x term and find E.
The second line is obviously wrong because you can't add [itex]x^2[/itex] to [itex]4a[/itex]. They have different units. It's not clear to me what you were trying to do.
  • · Replies 32 ·
  • · Replies 28 ·
