Anyone know of experiments to calculate the refractive indexes of liquids?
The discussion revolves around investigating the refractive index of liquids through various experimental approaches suitable for a school lab setting. Participants explore different methods and variables that could be incorporated into the experiments.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants suggest measuring the refractive index directly versus comparing it with known materials. They discuss the implications of the refractive index, including Snell's Law and phenomena like total internal reflection and dispersion. Ideas for experiments involving different light sources and varying conditions are also mentioned.
The discussion is ongoing, with participants providing various experimental ideas and considerations. There is a recognition of the need for multiple approaches to meet project requirements, and suggestions are made to explore visually engaging experiments.
Participants note the project requires theoretical backing and proof of results, indicating constraints on the types of experiments that can be conducted. The original poster expresses a need for more than one experiment to fulfill the project criteria.
JohnayG
For my AH Physics investigation I'm going to research the refractive index of a liquid and need a few different experiment ideas to perform within my pretty basic school lab.
An example of a feasible experiment would be much appreciated!
I have thought about changing the density/temperature of the liquid, and possibly use different light sources. But i need more variables please.
Think of measuring it directly vs ways of comparing it with a known material
The refractive index is the ratio between the speed of light in vacuum and the speed of light in the refracting material.
[tex]n=\frac{c}{v}[/tex] where [tex]v[/tex] is the speed of light inside the material.
The two main consequences of this relationship are the one summarized in Snell's Law, and the fact that the actual velocity of light in the material is slower.
An interesting phenomenon is that of total internal reflection, an experiment on that subject could be very interesting as well.
If you've got access to equipment that's accurate enough, you could actually look at the speed of light itself in the material.
If you're familiar with the concept of polarization and Brewster's Angle and have access to a polarizer, you can design an experiment that would include that concept as well.
Some other possible experiments could be on dispersion (The dependence of the index of refraction on wavelength) in the material and the formation of rainbows, for instance.
The possibilities are really endless!
If you really want a good experiment, I think you should find a concept or phenomenon that has to do with the index of refraction that really interests you (I posted a couple of examples, but really there are many many more), and perhaps even something that's visually stunning to wow the class, and just enjoy the experiment yourself.
Thanks for your help, i'll see how things go. its more a project to be handed in with proof of results etc than performed in front of a class however. It requires a theory and hence more than one way of proving it, ergo i need more than on experiment. But thanks for the ideas!
Rather than having an air to liquid medium (which I assume is what your going to do) how about a liquid to liquid medium? You can calculate where the light source should come out of medium 1 using snells law etc and then show that if you use a different medium that the light source will refract out at a different place. Just an idea :)
32K
21K
