Kinematics - Statics - Free Body Diagram
The problem involves two identical uniform beams positioned against each other on a floor, with the goal of determining the minimum angle they can make with the floor without falling. The context is rooted in kinematics and statics, particularly focusing on free body diagrams and the forces acting on the beams.
  • The original poster attempts to analyze the forces acting on the beams using a free body diagram but expresses confusion regarding the interactions between the beams, particularly whether there are horizontal and vertical forces involved.
  • Some participants question the nature of the forces, discussing the implications of symmetry and Newton's third law in relation to the vertical and horizontal components of the forces between the beams.
The discussion is ongoing, with participants exploring different interpretations of the forces involved. Some guidance has been offered regarding the symmetry of the forces, but there is no explicit consensus on the nature of the forces acting between the beams.
Participants are navigating assumptions about the forces acting on the beams, particularly in relation to their inclined position and the implications of static friction.
nahanksh
https://online-s.physics.uiuc.edu/cgi/courses/shell/common/showme.pl?courses/phys211/spring09/homework/11/two-beams/fig3a.gif
Two identical uniform beams, each of mass "M" and length "L", are symmetrically set up against each other on a floor with which they have a coefficient of static friction "u". The acceleration due to gravity is "g".
Find the minimum angle θmin that the beams can make with the floor without falling.
When drawing a Free Body Diagram, i figured out at the center of mass in each rod and the surface between rod and the ground..
But i am confused with the surface between rods.
Is there going to be only horizontal force(pushing each other) or since they are inclined, there should be both horizontal and vertical forces?
Really confusing...
Could someone help me out here?
Hi nahanksh! :smile:
From symmetry, the vertical components of force between the beams must be equal.
But good ol' Newton's third law says that the forces of each beam on the other must be equal and opposite.
So the vertical components must be zero. :wink:
Thanks for your reply.
Then there is no horizontal forces between the beams ?
From symmetry, the horizontal components of force between the beams must be equal and opposite.
Newton's third law agrees … the forces of each beam on the other must be equal and opposite.
So the horizontal components don't have to be zero! :smile:
