Gauge Fixing Term: Physical Effects & Role in Spin Components
The discussion centers on the role of gauge fixing terms in theoretical physics, particularly in the context of vector particles and gravity. Gauge fixing eliminates redundant degrees of freedom, specifically projecting out unnecessary spin components from the Lagrangian. For vector particles, gauge fixing reduces the four degrees of freedom to two or three, depending on mass. In gravity, employing harmonic gauge simplifies calculations without altering the physical content of the theory, especially in weak-field approximations.
  • Understanding of gauge symmetry in theoretical physics
  • Familiarity with Lagrangian mechanics
  • Knowledge of vector particles and their degrees of freedom
  • Basic principles of General Relativity (GR) and harmonic gauge
  • Research the implications of gauge fixing in Quantum Field Theory
  • Study the mathematical formulation of Lagrangians for vector particles
  • Explore the role of harmonic gauge in General Relativity
  • Investigate the connection between weak-field approximations and Newtonian gravity
The discussion is beneficial for theoretical physicists, graduate students in physics, and anyone interested in the mathematical foundations of gauge theories and their applications in particle physics and general relativity.
Neitrino
Hi...
Would you please advise me what does gauge fixing term do (physical point of view) ?
Does it eliminate unnecessary spin components from lagrangian for example:
Vector particle has two (massless case) or three (massive case) degrees of freedom.
Vector itself has four, and a vector (four component object) can handle spin-0 and spin 1 mode so adding a gauge fixing term does it project out spin-0 component ?
Or absence of spin-0 part is due to specific choice of kinetic term (F_mu_nu)...
Similarly in gravity... summetric tensor has 10 independent components and it can handle spin-0 spin-1 spin-2 modes... so does employment of harmonic gauge eliminate unnecessary modes or what role has it in this business?
Thanks
Hi neitrino,
The point of a gauge symmetry is that there's a redundancy in our description of the system; so physically, choosing a gauge is meaningless! The point is that you firstly have to choose some gauge, in order to actually write anything down at all, so you might as well pick one that makes the maths easy.
I can't say I'm familiar with harmonic gauge in GR, but having quickly looked it up the essential point seems to be the same; it doesn't alter the physical content of our statements, and it makes the maths easier in some problems- particularly when working in the weak-field approximation when we want to make contact between GR and Newtonian gravity.
  • · Replies 75 ·
11K
  • · Replies 87 ·
9K
  • · Replies 0 ·
  • · Replies 74 ·
