Feynman Diagram Question, Antiparticle
The discussion revolves around the interpretation and application of Feynman diagrams, particularly in the context of particle-antiparticle interactions and the associated momentum conservation rules. Participants explore the implications of using different types of propagators and the notation used in various papers, focusing on the emission of photons from fermions and the treatment of antiparticles.
  • One participant describes a process involving a particle decaying into an antifermion and a photon, questioning the momentum conservation equation and the direction of arrows in the Feynman diagram.
  • Another participant points out that certain particle interactions cannot occur due to charge conservation, indicating a misunderstanding of the original process described.
  • A later reply clarifies that the process is part of a larger diagram involving a meson decaying into a positron, electron, and photon, and raises questions about how the propagator changes when the photon is emitted from a positron versus an electron.
  • Concerns are expressed about the inconsistency in notation across different papers, particularly regarding how momenta and signs are treated in Feynman diagrams and propagators.
  • One participant asserts that when using Dirac spinors, the signs in the propagator and vertex do not need to be a concern, suggesting that the formalism automatically accounts for these factors.
Participants express differing views on the treatment of momentum and signs in Feynman diagrams, with no consensus reached on the best approach or notation. There is also disagreement regarding the implications of charge conservation in certain particle interactions.
Participants note limitations in the clarity of notation and definitions used in various papers, which may affect their understanding of momentum conservation and propagator behavior in different contexts.
Hepth
Lets say we have a process where:
Particle B(P) -> v(p2) + k
some particle effectively goes to an antifermion and a photon, with momentums P, p2, and k.
And the diagram is just straightforward, in arrow to vertex, out photon and out antifermion from vertex.
Now the arrow on the antifermion points inward, but that's for fermion/particle number right? Momentum conservation would still be P = p2+k correct? not P +p2 = k (Arrows).
Hi Hepth! :smile:
Sorry, not following you :redface:
you can't have e- -> e+ + γ because the charges don't add up,
and you can't change species and have eg proton -> e+ + γ because lots of other things don't add up. :confused:
Its effective, its not e- > e+ + gamma
its actually part of a much larger diagram. I might as well say it:
M (meson) -> positron + electron + photon
Its done through a penguin diagram, but can be approximated with an effective process.
Doing so, the photon can be emitted from either of the two fermions (positron/electron)
When doing the matrix element of the photon being emitted from the positron, the "propagator" between the meson vertex and the QED vertex is a positron. My REAL questions is does this propagator change somehow. Normally, for a fermion (like on the electron-emission side) the propagator would be :
[tex] \frac{\not q + m}{q^2 -m^2}[/tex]
Where q is just the final electrons momentum minus the photons, or the initial mesons minus the positrons.
When the POSITRON emits the photon, do the momentum conservation rules change, or is that all taken care of in the spinors? would the propagator change, since its a "different" dirac equation.
I know I would get a sign change from the QED vertex.
would the propagator change from:
[tex] \frac{i}{\not q -m} \rightarrow \frac{i}{-\not q -m}[/tex]
if p1 = electron
p2 = positron
P = meson
k = photon
would the positron emission vertex have:
q = p2 + k
or because of arrows :
q = p2 -k
It seems like I'm running into problems reading papers where everyone uses different notation. Some like to mark momenta on the graphs of antiparticles with a minus already, others take it into account when doing conservation, some take it into account in the propagators. I guess what would answer my question would be if someone could, from feynman rules, write down or show me somewhere (having a hard time finding it) the amplitude for the compton, uncrossed-photon processes. One for electron, one for positron.
I know the probability will be the same, but its the sign convention I'm worrying about BEFORE squaring. Would they be:
[tex] \bar{u}\left(- i e \gamma^{\mu}\right) \epsilon_{\mu} \frac{i \left(\not q + m\right)}{q^2-m^2} \epsilon^{*}_{\nu}\left(- i e \gamma^{\nu}\right) u[/tex]
with [tex]q = p_f + k_2 = p_i +k_i[/tex]
[tex] v\left(+ i e \gamma^{\mu}\right) \epsilon_{\mu} \frac{i \left(\not q + m\right)}{q^2-m^2} \epsilon^{*}_{\nu}\left(+ i e \gamma^{\nu}\right) \bar{v}[/tex]
with [tex]q = p_i - k OR = p_i + k[/tex]
or does the propagator change in sign on the top "q", BEFORE I fill in what q is, etc.
got it
The answer to this question, I believe, has to do with the fact that when using DIRAC spinors, you never need to worry about signs in the propagator or the vertex. So, for example:
fermion-fermion-photon vertex is always [tex]\qquad ie\gamma^\mu[/tex]
fermion propagator is always [tex]\qquad\frac{i(p\!\!\!\slash+m)}{p^2-m^2}[/tex]
and the direction of the momentum vs the spinor arrow is irrelevant (so no need to distinguish between fermions and antifermions in the propagator). This would NOT be true if using Weyl spinors! But as long as you use Dirac spinors, all the signs should automatically work themselves out.
