Thread Closed
Matlab generating parametric curves
Share Thread Thread Tools
Jan14-10, 05:04 PM   #1
I want to graph the following parametric curve using matlab:
x = 31cos(t)-7cos(31/7)t
y = 31sin(t)-7sin(31/7)t
0 ≤ t ≤ 14π
This is the code I used:
Code:
syms t
t=[0:1:19*pi]
x=31*cos(t)-7*cos(31/7)*t;
y=31*sin(t)-7*sin(31/7)*t;
plot(t,y,t,x)
But the graph which Matlab generated is very different from what it's supposed to look like. Is there a problem with my codes? How do we graph this parametric curve (it's a complex curve)? Thanks.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Jan15-10, 04:07 AM   #2
Recognitions:
When you use a (2D) parametric equation, you don't express x or y in terms of each other, you do it in terms of a third variable (as you've done). However, at the end of the day, you should still have a set of X-Y coordinates.
Instead of plotting x as a function of t, and then plotting y as a function of t (as you're doing), just plot y as a function of x:
>> plot(x, y)
Jan15-10, 02:13 PM   #3
Well, the curve I'm trying to produce is supposed to look like this:
But when I even use this code:
Code:
syms t
t=[0:1:19*pi]
plot(x, y)
I get this graph:
I can't see the problem.
Jan15-10, 02:27 PM   #4
Recognitions:
Quote by roam View Post
Code:
syms t
t=[0:1:19*pi]
plot(x, y)
I get this graph:
Are you sure of your equations? I Googled for parametric spirograph equation and got the following webpage:
http://linuxgazette.net/133/luana.html
You may want to try again with:
x=31*cos(t) - 7*cos((31/7)*t);
y=31*sin(t) - 7*sin((31/7)*t);
I don't know if you know about the MATLAB axis command, but you can use it (or rather 'axis square') to have equal scaling on both axes:
http://www.mathworks.com/access/help.../ref/axis.html
EDIT: You may also wish to use a smaller step size for t, say 0.1 or 0.01 instead of 1, as you currently have it.
Jan15-10, 03:25 PM   #5
As MatlabDude has already pointed out, the problem lies with the parametric equations you're using. For example, the following equivalent Mathematica code
Code:
x[t_] := 31 Cos[t] - 7 Cos[31/7] t;
y[t_] := 31 Sin[t] - 7 Sin[31/7] t;
ParametricPlot[{x[t], y[t]}, {t, 0, 19 \[Pi]}]
gives the parametric plot
On the other hand, the modified parametric equations
Code:
x[t_] := 31 Cos[t] - 7 Cos[31 t/7];
y[t_] := 31 Sin[t] - 7 Sin[31 t/7];
give you the desired plot:
Jan15-10, 05:22 PM   #6
Okay thanks A LOT guys. :)
Jan15-10, 07:02 PM   #7
By the way, when you are ploting this in Mathematica, what is the code for changing the color of the plot?
Thread Closed
Thread Tools
Similar Threads for: Matlab generating parametric curves
Thread Forum Replies
Parametric curves Calculus & Beyond Homework 13
Parametric curves applications Calculus & Beyond Homework 5
Parametric Curves Calculus 0
Parametric Curves..HELP!!! Introductory Physics Homework 2
