Friction coefficient of drawer slides
The discussion revolves around the friction coefficient of drawer slides, particularly in the context of their application in robotic mechanisms. Participants explore the variability of the coefficient based on different slide and surface combinations.
  • Exploratory, Technical explanation, Debate/contested
  • One participant notes that the friction coefficient is highly variable and suggests conducting a specific experiment to determine it for a given slide and surface combination.
  • Another participant expresses a desire for approximate values, indicating that they are looking for general information rather than precise measurements.
  • A third participant mentions that rolling element bearings typically have a coefficient of friction around 0.002, while noting that non-rolling element bearings, such as those with Teflon bushings, will have a higher coefficient.
Participants do not reach a consensus on a specific value for the friction coefficient, highlighting the variability and the need for context-specific measurements.
The discussion acknowledges the dependence on specific slide and surface combinations, and the lack of a universal coefficient for drawer slides.
yanikomer
Hello everyone
Do you know approximately the friction coefficient in drawer slides? I am going to use it in a robotic mechanism.
Thanks
I mean... that's incredibly variable. If you have a specific slide, and you know what surface it will be sliding on, then there is a (semi-)quick little experiment you can do to find the coefficient, but the coefficient is going to be different for every single slide/surface combination.
i just want to know if there is somebody who has used these slides and known the coefficient of the friction.
You can just say "it must be about..." this is enough for me.
  • · Replies 43 ·
  • · Replies 18 ·
