Find vector parallel to yz plane and perpendicular to other given vector
The problem involves finding a vector u that is parallel to the yz-plane and perpendicular to a given vector v=<5,0,4>. Participants are exploring the relationships between vector components and their geometric interpretations.
  • The original poster attempts to find a unit vector parallel to the yz-plane and considers using the cross product, but realizes it would not yield the desired result. They express confusion about how to solve the resulting equations with multiple unknowns.
  • Some participants suggest simpler forms for vectors parallel to the yz-plane and question the necessity of using cross products or unit vectors.
  • Others raise concerns about the conditions for perpendicularity and express a preference for using the dot product to find the correct components of the vector.
The discussion is ongoing, with participants providing hints and alternative approaches. There is recognition of valid forms for the vector u, and some participants are questioning their understanding of the relationships between the vectors involved. No explicit consensus has been reached, but guidance has been offered regarding the use of the dot product.
Participants are navigating the constraints of the problem, including the requirement for the vector to be both parallel to the yz-plane and perpendicular to a specific vector. There is some confusion regarding the use of different vector operations and their implications.
Raziel2701
Find a vector u that is parallel to the yz-plane and perpendicular to the vector v=<5,0,4>.
2. The attempt at a solution
I first tried to find a unit vector parallel to the yz-plane, I then crossed this vector with vector v, but then I remembered that the resulting vector would be perpendicular to both, so that wouldn't work.
Let me be more precise:
1. I found a unit vector to (0,1,1)
I got (0,1/sqrt(2), 1/sqrt(2))
2. I was going to cross this vector with v (5,0,4) but then I realized that the resulting vector would be perpendicular both the yz plane and vector v so I didn't follow through.
So then :
1. I crossed u(a,b,c) with the yz plane (0,1,1) and got:
(b-c)i -(a)j +(a)k and set it equal to zero because I want them to be parallel.
Clarifying that I'm using a,b, and c as my unknowns.
2.I tried dotting this vector I found with vector v(5,0,4) and I set them equal to zero but now I have an equation with three unknowns but I don't know how to solve them.
Here's what I got:
5b-5c +4a=0
Hi Raziel2701! :wink:
oooh, you're making this so complicated :cry:
forget cross products, forget unit vectors …
what's a typical vector parallel to the yz-plane? …
now when is it perpendicular to <5,0,4> ? :smile:
I don't think I'm following. Apparently any vector of the form <0,y,z,> as long as y and z are equal should be parallel to the yz plane correct?
So if that is right then that I get, but as to when it is perpendicular to vector <5,0,4>, I honestly don't know. I'm rather stubborn about using the dot product to find what those vector components would be, but I can't get the right answer yet.
Any further hints would be great.
No, you are following, you just think you aren't. :biggrin:
Yes, any (0,b,c) will do it. :smile:
Why this aversion to the dot product … it's much simpler than the cross product anyway! :smile:
So, what is (0,b,c).(5,0,4) ? And what does it need to be? :wink:
Ok, so I got a valid answer, but there's still something that seems wrong.
So I got <0,2,0> for my answer, the middle component can be any number apparently, and this vector is indeed perpendicular with the vector <5,0,4> but unless my math is wrong, the dot product of my answer and <0,1,1> does not give me an angle of zero to indicate that the two vectors are parallel but rather, I get an angle of 45 degrees.
So what's up with that?
And thank you for your help, I like the puzzling, yet helpful advice rather than straight out giving me an answer and an explanation.
Yes, <0,b,0> for any value of b will do.
It lies in the yz-plane, and it's perpendicular to <5,0,4> because the dot product is 5*0 + 0*b + 4*0.
(0,1,1) is a vector you invented in your first post … i did say to forget it! :wink:
ok, now just go back to your fist post and check why you didn't need a unit vector, and why the cross product wouldn't work …
you can use cross product to make a new vector perpendicular to a given vector, but not to check that two given vectors are perpendicular … for that, you need the dot product. :smile:
19K
