Thread Closed
Functions of Complex Variables
Share Thread Thread Tools
Jan22-10, 07:54 AM   #1
{Q 6.2.2 from Arfken "Mathematical Methods for Physicists"}
Having shown that the real part [tex]u(x,y)[/tex] and imaginary part [tex]v(x,y)[/tex] of an analytic function [tex]w(z)[/tex] each satisfy Laplace's equation, show that [tex]u(x,y)[/tex] and [tex]v(x,y)[/tex] cannot have either a maximum or a minimum in the interior of any region in which [tex]w(z)[/tex] is analytic. (They can have saddle points)
2. Relevant equations
Cauchy-Riemann (CR) relations for analyticity of the function [tex]u_x=v_y[/tex] and [tex]u_y=-v_x[/tex] where subscript stands for partial differentiation with respect to that variable.
[tex]\nabla^2u=0[/tex] and [tex]\nabla^2v=0[/tex] (it follows from CR relations and proves that analytic function satisfies Laplace's equation)
3. The attempt at a solution
The local minimum/maximum points are to satisfy [tex]u_x=0[/tex] and [tex]u_y=0[/tex]
and
[tex]M=u_{xx}u_{yy}-(u_{xy})^2>0[/tex]
[tex]\nabla^2u=u_{xx}+u_{yy}=0\therefore u_{xx}=-u_{yy}[/tex]
[tex]M=-u_{yy}^2-u_{xy}^2\leq0[/tex]
...and it looks like totally wrong direction...
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Jan22-10, 01:04 PM   #2
i think you proved it, for a function of two variables to have a min or max
[tex]
-u_{yy}^2-u_{xy}^2 > 0
[/tex]
but for a saddle point
[tex]
-u_{yy}^2-u_{xy}^2 < 0
[/tex]
since the square of two real numbers is always positive, the condition will give only a number <= 0.
if it is = 0 you cannot conclude anything
if it is <0 it is a saddle point
so u(x,y) and v(x,y) cannot have either a maximum or a minimum in the interior of any region in which w(z) is analytic.
Jan22-10, 01:21 PM   #3
Wait, the square of a real number is non-negative, so haven't you completely ignored the case where you can have a saddle point or a local extremum?
Jan22-10, 04:51 PM   #4
Precisely, the fact that [tex]M[/tex] can be zero doesn't allow proof to be completed. The only way to complete it is to show that for points where [tex]u_x=0[/tex] and [tex]u_y=0[/tex] [tex]M[/tex] cannot be zero.
or there is probably different approach which I cannot see...
Jan22-10, 06:16 PM   #5
Well, what does Gauss's divergence theorem yield for the integral of the Laplacian of U over a small area containing a hypothetical maximum/minimum of U?
Jan23-10, 05:00 AM   #6
From Gaussian theorem we have
[tex]\int _V\nabla^2 u \, dV=\int_S \nabla u \cdot n\, dS[/tex]
[tex]0=\int_S \nabla u \cdot n\, dS[/tex]
I intuitively see that zero flux of [tex]\nabla u[/tex] implies that [tex]u[/tex] cannot have minimum or maximum but do not fully grasp it.
If it is to be true, then in the enclosed region where [tex]u[/tex] is minimum/maximum [tex]\nabla u[/tex] must be all negative/positive but cannot see why this is true.
Jan23-10, 06:33 AM   #7
You have to make your intuition more explicit. Intuitively we see a maximum that looks like a mountain top, so we see a gradient that points away from the mountain top. You then have to think about how to translate that to pure math. What is clear is that you cannot see this effect when expanding U to first order around the maximum, you have to go to second order.
So, you can make the following plan. Let's try to use the fact that U is analytic. U has a series expansion and you can write U around its maximum as a quadratic plus an error term. This will capture the above picture correctly. If you now use Gauss' theorem and substitute in the flux term involving nabla U the second order expansion plus error term, you should be able to prove that the flux term has to be strictly positive if U has a maximum or strictly negative if U has a minimum.
Jan23-10, 07:49 AM   #8
Thanks.
Thread Closed
Thread Tools
Similar Threads for: Functions of Complex Variables
Thread Forum Replies
[complex functions] finding complex roots in 1+z+az^n Precalculus Mathematics Homework 2
Complex conjugate variables as independent variables in polynomial equations Linear & Abstract Algebra 0
Complex Variables. Complex square root function Calculus & Beyond Homework 0
[SOLVED] Complex Variables. Problem about complex sine. Calculus & Beyond Homework 2
two functions in two variables General Math 6
