Solving Equation: x² - 3x - 40 = 0
  • Thread starter Thread starter Gringo123
The discussion centers on solving the quadratic equation x² - 3x - 40 = 0 using the Rational Root Theorem and trial and error factoring methods. Participants confirm that the correct factors are (x + 5)(x - 8), leading to the solutions x = -5 and x = 8. The conversation highlights the importance of identifying integer factors of the constant term, in this case, 40, to find the roots of the equation. Additionally, it notes that if integer factors do not yield a solution, alternative methods such as completing the square or the quadratic formula can be employed.
  • Understanding of quadratic equations and their standard form.
  • Familiarity with the Rational Root Theorem.
  • Basic knowledge of factoring techniques.
  • Awareness of alternative methods for solving quadratics, such as the quadratic formula.
  • Study the Rational Root Theorem in detail to understand its applications.
  • Learn how to apply the quadratic formula to solve quadratic equations.
  • Explore the method of completing the square for solving quadratics.
  • Practice factoring various quadratic equations to reinforce understanding of the concepts.
Students studying algebra, educators teaching quadratic equations, and anyone looking to improve their problem-solving skills in mathematics.
Gringo123
My Maths textbook gives the following equation:
x squared - 3x - 40 = 0
.. and it gives the following as a model answer: (where I've wriiten right or wrong there is a tick or a cross)
try 2 x 20x, 4 x 10x, 5 x 8 (right)
(x-5) (x + 8) (wrong)
(x+5) (x-8) (right)
x = -5 or 8
I have no idea what this method is and why it has been used here. Can anyone please expain it to me?
Thanks
Hi Gringo123! :smile:
This is the rational root theorem
basically, if the roots are whole numbers, then they have to be factors of 40 (times ±1).
So first they tried ±2 and ±20 (by putting eg 2 into the equation to see if it comes out 0, as it should), then they tried ± 4 and ±10, then they tried ±5 and ±8 …
woohoo! it's -5 and 8 ! :biggrin:
See http://en.wikipedia.org/wiki/Rational_roots" for more details. :wink:
(x+5) (x-8) (right)
x = -5 or 8
Thanks
Essentially, they are using a "trial and error" method of factoring the left side. I presume the textbook has already show that (x+ a)(x+ b)= x2+ (a+b)x+ ab. In order that you have (x+a)(x+b)= x+ (a+b)x+ ab= x2- 3x- 40, you must have a+ b= -3 and ab= -40. So start looking for integers factors of 40: 1* 40, 2*20, 4*40, 5*8, 8*5, 10*4, 20*2, and 40*1. Since it doesn't matter which you call "a" and which "b", you don't need to look at "8*5, 10*4, 20*2, and 40*1", they are the same as "1* 40, 2*20, 4*40, and 5*8". I don't know why they did not include "1*40"- perhaps they thought that was too obviously wrong.
Since the product of two positive or two negative numbers is positive, in order to get ab= 40, one factor must be positive and the other negative. Now we check each of those to see if they add to -3: 1- 40= -39 not -3; 2- 20= -17, not -3; 4- 10= -6, not -3; 5- 8= -3. success!
Okay, we now know the numbers are a= 5, b= -8: check: (x+ 5)(x- 8)= x2+ (5-8)+ 5(-8)= x2- 3x- 40.
Now we know that x2- 3x- 40= (x+ 5)(x- 8)= 0. Since we also know that if the product of two numbers is 0, at least one of the numbers must be 0 (that is a special property of "0" and does not work if the product is any number except 0), we know that either x+ 5= 0 or x- 8= 0. From the first we see that x= -5 is a solution to the equation, from the other, we know that x= 8 is a solution.
By the way, it might happen that NONE of the integer factors of ab, the constant term in the polynomial, add to the coefficient of x. In that case, it cannot be factored with integer coefficients. Fortunately, for quadratic equations, there are other methods, such as "completing the square" or the "quadratic formula", to solve them.
  • · Replies 17 ·
