Sound waves and the doppler effect
The discussion centers on a physics problem involving sound waves and the Doppler effect, specifically analyzing a jet's speed as it travels from point A to B while a person on the ground hears the sound from A. The problem involves calculating the speed of the jet at point B, given its initial speed of 170 m/s at A, an angle of 36 degrees, and the speed of sound at 343 m/s. The solution requires applying kinematic equations rather than focusing on the Doppler effect, leading to the conclusion that the speed at B is 239 m/s after considering acceleration and the geometry of the situation.
  • Kinematic equations for motion analysis
  • Understanding of sound wave propagation
  • Basic trigonometry, specifically sine functions
  • Knowledge of acceleration and velocity concepts
  • Study kinematic equations in detail, focusing on motion with constant acceleration
  • Learn about sound wave properties, including speed and frequency relationships
  • Explore trigonometric functions and their applications in physics problems
  • Investigate the Doppler effect and its relevance in sound wave scenarios
Students studying physics, particularly those focusing on kinematics and sound wave behavior, as well as educators seeking to clarify concepts related to motion and sound propagation.
seb26
A jet is flying horizontally from A to B. When the plane is directly overhead at B, a person on the ground (C) hears the sound coming from A. ABC is a right triangle in B. The angle BCA = 36 degrees.
The average temperature is 20 degrees Celsius. If the speed of the plane at A is 170 m/s, what is the speed at B, assuming that it has constant acceleration?
f=1/T f: frequency; T: period
v= λ*f = λ/T λ: wavelength
fobserver= fplane*((v+vo)/(v+vp)) v=343m/s
First off I don't see what steps to take to come up with the answer. There must some implicit data to take into consideration but I can't figure it out.
What I assume, since there is a right triangle with an angle given, is that one distance has to be found (AC) to find AB with sin.
I found the acceleration by taking t=1second. I know that the sound travels at 343m/s on AC and the speed the plane has after one second on AB is found by calculating vplane= sin(36)*343= 201.6m/s so the acceleration is a= (201.6-170)/1s= 31.6m/s2
I can't figure out how to get the distance from A to C or A to B.
PS: those values are given from my homework given by the teacher, on the book the same problem has 164m/s for the speed of the plane at A, same angle. The answer for the speed at B is 239m/s
Hi seb26, welcome to PF.
your relevant equations are irrelevant, because the problem is not based on Doppler effect.
It is just kinematic equation.
If vi is the initial velocity of the jet at A, vs is the velocity of the sound and t is the time taken by the jet to travel from A to B, then
AB = vi*t + 1/2*a*t^2 ...(1)
Sound starting form A takes the same time t to reach C. So
AC = vs*t...(2)
AB/AC = sinθ...(3) And vf - vi = at...(4)
Using above hints find the velocity of the jet at B.
After a whole day of trying to crack this problem with my buddy, your advice is what led us to the answer. God bless you and those of you who help students like us out.
Peace,
Riaz
  • · Replies 27 ·
