Troubleshooting Graph Plotting in Mathematica: K Value Error
  • Context: Mathematica
  • Thread starter Thread starter madness
    Mathematica
The discussion revolves around troubleshooting a graph plotting issue in Mathematica, specifically regarding the function f(x)=K(1-x)^{\frac{-3}{8}}. Participants explore the behavior of the graph based on different values of K and the command used for plotting.
  • Homework-related
  • One participant reports an issue with the graph starting negative at x=0 when K=325, questioning whether they made an error in their command.
  • Another participant suggests verifying whether the graph actually starts at (0, 0) or at (0, 325), proposing a modification to the plot command to set the axes' origin.
  • A later reply indicates that the suggested modification resolved the initial participant's problem, acknowledging their inexperience with the software.
The discussion appears to have resolved the initial issue raised by the first participant, but there is no explicit consensus on the underlying behavior of the function or the implications of different values of K.
The discussion does not clarify the assumptions regarding the function's behavior or the specific conditions under which the graph is expected to start at certain points.
madness
I just got Mathematica last night and am trying to use it for the first time. I'm trying to plot a graph [tex]f(x)=K(1-x)^{\frac{-3}{8}}[/tex] but it's not working right. I tried first with K = 325 (for physical reasons) and the graph started negative at x=0. If I choose K to be almost anything other than 325 the graph starts at 0 which is also wrong. The command I gave was Plot[325(1-x)^(-3/8), {x,0,0.9}]. Did I do something wrong?
download the following software which is much more easier than mathematica
http://www.grapheeasy.com/download/ge2en.exe
Are you sure it starts at 0?
Or does it start at the crossing of the axes? Look carefully if the intersection point is indeed (0, 0), and not (0, 325).
If you insist on having it in the origin, usr
Code:
Plot[325(1-x)^(-3/8), {x,0,0.9}, AxesOrigin->{0, 0}]
Thanks that solves the problem. I'm really new at this so I'm still trying to get used to it all.
