Thread Closed
pressure in u-tube of mercury with added water
Share Thread
Jan27-10, 09:09 PM   #1
A simple open U-tube contains mercury. When 11.8 cm of water is poured into the right arm of the tube, how high above its initial level does the mercury rise in the left arm?
Hint: At the level of the interface between the water and the mercury, the pressure on the left must balance the pressure on the right. In each the pressure is the gauge pressure of a column of liquid standing above that level.
2. Relevant equations
P=pgh
3. The attempt at a solution
the pressure at the surface of interaction in the right arm should equal the pressure, at the same height, of the mercury in the left arm. therefore:
p(water)gh(water)=p(mercury)gh(mercury)
1*10*11.8=13.534*10*h
11.8/13.534=h
.872=h
But the online thing says that isn't the right answer. where am i going wrong?
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Jan27-10, 10:56 PM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
The amount of the mercury iremains the same. If its surface is depressed by d in the right arm, it should rise by d in the left arm, so you have h=2d length of mercury balancing the water column, but the change of height is d, half of your value.
ehild
Thread Closed
Similar discussions for: pressure in u-tube of mercury with added water
Thread Forum Replies
U-shaped tube-- how far does the mercury rise when water is poured into one side? Introductory Physics Homework 1
Water and Mercury Pressure Introductory Physics Homework 1
Hg in U-shape tube, water is added. final h Hg? Introductory Physics Homework 1
Fluid Mechanics - U-tube and mercury Introductory Physics Homework 1
Pressure in a mercury tube Introductory Physics Homework 8
