Electric Field Due to Infinite Line Charge
The discussion revolves around calculating the electric field due to an infinite line charge using integration based on the inverse square law. Participants are exploring the setup and implications of the integral involved in this context.
  • Participants are attempting to identify the correct variables for the integral and questioning the appropriateness of the limits of integration. There is discussion about the behavior of the integral as limits approach infinity and whether a finite limit could be more manageable.
Some participants have provided guidance on setting up the coordinate system and clarifying the roles of the displacement vectors in the integral. Others are expressing concerns about the convergence of the integral and exploring alternative approaches to handle the infinite limits.
There is uncertainty regarding the correct interpretation of the integral and its limits, as well as concerns about the mathematical behavior of the expression when evaluated over infinite bounds.
SimbaTheLion
"Compute the electric field due to an infinite line charge by integrating the expression obtained from the inverse square law."
I think that the equation required is:
[itex]E(\bold{r}) = \frac{1}{4 \pi \epsilon_0} \int_{-\infty}^{+\infty} \frac{(\bold{r} - \bold{r}') \sigma}{|\bold{r} - \bold{r}'|^3} dx[/itex]
Well, I don't know what to put in the above integral for r and r', or even if the above integral is even right...
Thanks for any help :) .
Your equation looks correct.
Build a coordinate system. Include the wire in some convenient place, like along the x-axis. The wire will extend to plus and minus infinite x. As presented, the integral already assumes the wire lies parallel to the x-axis.
r is a displacement vector that varies with x, and locates points within the wire.
r' is a displacement vector of the point for which we wish to calculate the electric field. It is a constant with respect to the variable of integration, x.
im working on the same problem. it appears that if infinite limits of integration are used the expression blows up, is it better to set the limits from 0-> L and then take the limit as L goes to infinity?
Mmm, I'm getting an integral of something similar to 1/x² between -infinity and infinity, that doesn't look good...
[tex]\int_{-\infty}^{+\infty} \frac{dx}{(x^2+y^2)^{3/2}}= \left( \frac{x}{y^2 \sqrt{y^2+x^2}} \right) |_{-\infty}^{+\infty}[/tex]
The main observation you need to make to solve this is:
[tex]\lim_{x \rightarrow \infty} \frac{x}{y^2 \sqrt{y^2+x^2}} = \frac{1}{y^2}[/tex]
Since x is a first order variable on both the numerator and denominator.
  • · Replies 23 ·
