Understanding Zeroth Order Approximations in Landau Level Equations
  • Context: Graduate
  • Thread starter Thread starter bobydbcn
    Landau
This discussion focuses on the zeroth order approximations in Landau Level equations, specifically analyzing the Hamiltonian H=\frac{1}{2}(\vec{p}+\frac{\vec{A}}{c}) and the radial equation. As r approaches infinity, the equation simplifies to [-\frac{1}{2}\frac{d^2}{dr^2}+\frac{1}{2}\omega_{L}r^2]u(r)=0, leading to the conclusion that the term [E-m\omega_{L}]u(r) cannot be omitted in the zeroth order approximation. Participants confirm that the right-hand side becomes negligible compared to the left-hand side's second term, justifying its exclusion in this approximation. Additionally, inquiries about experimental verification of Landau levels and recommended literature on zeroth order approximations are raised.
  • Understanding of Hamiltonian mechanics
  • Familiarity with differential equations
  • Knowledge of Landau levels and quantum mechanics
  • Basic concepts of polar coordinates in physics
  • Research experimental methods for verifying Landau levels
  • Study "Quantum Mechanics: Concepts and Applications" by Nouredine Zettili for insights on zeroth order approximations
  • Explore advanced topics in Hamiltonian dynamics
  • Learn about perturbation theory in quantum mechanics
Physicists, quantum mechanics students, and researchers interested in Landau levels and approximations in quantum systems.
bobydbcn
The hamiltonian is [tex]H=\frac{1}{2}(\vec{p}+\frac{\vec{A}}{c})[/tex]. We investigate this problem at a polar coordinate [tex](r,\theta)[/tex]. The radial equation is
[tex][-\frac{1}{2}\frac{d^2}{dr^2}+\frac{1}{2}(m^2-\frac{1}{4})\frac{1}{r^2}+\frac{1}{2}\omega_{L}r^2]u(r)=[E-m\omega_{L}]u(r)[/tex]
in order to find the wavefunction, we must investigate the behavior at the infinity of the differential euqtion.my question is that why the approximate equation take this form at infinity.[tex]r\rightarrow\infty[/tex], the equation becomes
[tex][-\frac{1}{2}\frac{d^2}{dr^2}+\frac{1}{2}\omega_{L}r^2]u(r)=0[/tex].
by the way, the energy is [tex]E=\omega_L(2n+|m|+m+1)[/tex]. we can see that when [tex]r\rightarrow\infty[/tex], then [tex]n\rightarrow\infty[/tex], so the energy above becomes infinity. then we can't omit [tex][E-m\omega_{L}]u(r)[/tex] in the above approximate equation. In my opinion, the equation should be written in the follow formulation:
[tex][-\frac{1}{2}\frac{d^2}{dr^2}+\frac{1}{2}\omega_{L}r^2]u(r)=[E-m\omega_{L}]u(r)[/tex]
Is that right? What is the reason?
The right hand side of your equation becomes negligible compared to the second term on the left hand side so you drop it a a zeroth order approximation. The second derivative is the only term which can compensate the second term, hence you keep it.
Thank you very much. I got it. Is there experiment that varify the landau level? Can you suggest a book to me about the zeroth order approximation?
  • · Replies 20 ·
