Dynamics and Forces: Solving for Safety Line Tightness and Friction Force
  • Thread starter Thread starter Omelette
    Dynamics Forces
The discussion revolves around two physics problems related to dynamics and forces. The first problem involves an astronaut connected to a spacecraft by a safety line and requires determining the time it takes for the line to become tight after the astronaut pushes away. The second problem concerns a horizontal force acting on an object and seeks to find the friction force opposing its motion.
  • Participants discuss the application of conservation of momentum to find the velocity of the spacecraft and the time for the safety line to become tight. There are attempts to apply kinematic equations to solve for time and questions about the role of mass in the first problem. In the second problem, participants explore the relationship between net force, applied force, and friction force.
The discussion is progressing with some participants providing calculations and corrections to earlier attempts. There is a recognition of the need to adjust the approach to the first problem based on the relative velocities of the astronaut and spacecraft. However, there is still uncertainty regarding the second problem, with participants seeking further guidance.
Participants are working under the constraints of multiple-choice answers for the first problem, which may influence their calculations. There is also a diagram referenced for the second problem that is not visible in the text.
Omelette
Q1) After a 1.30 x 10^2kg astronaut (incl. equipment) connects a safety line (length = 22.0m) to herself and to the spacecraft (mass = 2.80 x 10^3kg), she pushes against the craft and moves away at a constant velocity of 9.0m/s. How long does it take the safety line to become tight?
Q2) A 3.0kg object is pulled along a horizontal surface as shown in the diagram below by a horizontal force of 2.0N. If the object is accelerating at a rate of 1.2m/s^2, what is the force of friction acting on the object? (Diagram below).
Fnet = ma
d = volt + .5at^2
a = (Vf - Vo)/2
d = (Vf + Vo)/2 * t
Vf^2 = Vo^2 + 2ad
Ff = μFn
Q1) I thought to set d = 22, Vo = 0, Vf = 9, and solve for t using the 4th equation, but that answer isn't one of the choices. I think maybe the masses of the objects need to be used, but I don't know how they may help.
Q2) I used F = ma, and so Fnet = (3)(1.2) = 5.2 N (which is also on the diagram). I thought about Fnet = Fapp - Ff, and tried to solve for Ff by subtracting Fnet from Fapp, but that isn't one of the choices as well.
I don't really know where to start with these questions.
Help would be much appreciated! Thanks!
Initially astronaut are at rest with respect to each other. After the push astronaut moves with the velocity va. Using the conservation of momentum, find the velocity of the spacecraft vs. Both are moving in the opposite. The relative velocity between them is (va+vs). So time to move a distance d is t = d/(va+vs)
Using the conservation of momentum, I found the velocity of the spaceship to be v = p/m --> v = -1170/2800 = -0.41786m/s. Then I solved for t by doing t = d/(va + vs) = 22/(9 - 0.41786) = 2.56s, but the multiple choice answers are either 0.418s, 2.34s, 0.900s, or 2.44s.
Does anyone know how I should go about solving Q2?
Thanks again for your help!
22/(9 - 0.41786)
It should be 22/(9 + 0.41786) because when the two particles are moving in the opposite direction, their relative velocity is the sum of their velocities.
Ohh, I see that now. Thank you! I found the answer to be 2.34s.
