Angular Momentum conserved with friction?
The discussion revolves around a conceptual physics question regarding the conservation of angular momentum when a non-rotating disk is dropped onto a rotating disk. The scenario involves friction between the disks and raises questions about the effects of energy loss due to friction on angular momentum conservation.
  • Participants explore the relationship between angular momentum and energy, questioning whether energy loss through friction affects angular momentum conservation. Some express confusion about the role of friction and external forces in this context.
Participants are actively engaging with the question, with some providing insights into the principles of angular momentum conservation. There is a mix of interpretations regarding the impact of friction and energy loss, but no consensus has been reached yet.
There is an ongoing debate about the nature of friction as either an internal or external force and its implications for angular momentum. Participants are also considering the effects of sound and heat generated during the interaction of the disks.
theRIAA
This was a conceptual question on my physics exam:
True or false: You drop a non-rotating disk onto a rotating disk. When they hit they slide against each other with friction for a few seconds before they both start rotating at the same rate together. Because of losses due to that friction, angular momentum will NOT be conserved. (No other information was given)
I put True, the "correct" answer was False.
Am I wrong? Won't energy be lost as heat and sound through friction?
Welcome to PF!
Hi theRIAA! Welcome to PF! :smile:
D'oh! :rolleyes:
Yes, you're absolutely right … but you haven't answered the question!
The question asks about angular momentum, and you've answered (correctly) about energy.
Energy behaves completely separately from both ordinary and angular momentum.
Angular momentum (about a point) is always conserved (provided there is no external torque about the point, and in this case they asked you only to consider the effects of the friction between the discs, which is internal :wink:).
so.. even if the disks make a thunderous grinding sound and shot off sparks for an hour before spinning together... they will still end up with the same angular velocity as ones that made hardly any sound at all? I understand force and momentum act differently.. but isn't some momentum lost?
Momentum is for ever. o:)
Without an external force in that direction, it can't be lost.
Angular momentum is for ever.. o:)
Without an external torque about that point, it can't be lost.
Of course, sparks shooting off will carry away angular momentum. :wink:
I'm assuming friction is non-conservative. Some of this friction force from is transferred to the disks, while the rest is converted into heat and sound. This non-conservative friction is the external force in the direction opposite to momentum.
I refuse to believe friction plays no role unless someone logically explains how an unlimited amount of sound and heat can be produced without effecting the final angular velocity in this problem.
Yes, it is non-conservative.
But it's not external. :smile:
the sound waves created heat up the environment, the environment is external...
Sound is omni-directional, so how can it carry away (net) angular momentum? :smile:
Sound waves are converted from angular momentum, into energy by friction. Friction is caused by vibrations of the disks.The disks vibrate to create sound by pushing against air molecules. air has weight, vibrations use momentum.
(just got up :zzz: …)
theRIAA said:
… air has weight, vibrations use momentum.
Still omni-directional. :wink:
18K
