Thread Closed
Force exerted by two charges
Share Thread Thread Tools
Feb1-10, 06:59 PM   #1
Two point charges are placed on the x-axis as follows: one positive charge, q1, is located to the right of the origin at x= x1, and a second positive charge, q2, is located to the left of the origin at x= x2.
What is the total force (magnitude and direction) exerted by these two charges on a negative point charge, q3, that is placed at the origin? Use [tex]\epsilon_{0}[/tex] for the permittivity of free space. Take positive forces to be along the positive x-axis. Do not use unit vectors.
2. Relevant equations
Coulomb's Law: F = [tex]\frac{1}{4\pi\epsilon_{0}}\frac{\left|q_{1}q_{2}\right|}{r^{2}}[/tex]
3. The attempt at a solution
MasteringPhysics keeps giving me a "Check your signs error". Yet, as far as I can tell, I should be subtracting the force which is going left / the negative direction (ie, q2) from the force going to the right (ie, q1).
Any hints?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Feb1-10, 10:28 PM   #2
My apologizes if the "attempt at a solution" section appeared blank for anyone -- I have changed the link so that users who are not logged in can now see the link.
Feb2-10, 07:53 AM   #3
u can find the electric field at the origin from the charge q1 and q2 and then u can find the force using F= q3 * E .. try this one, I hope it will work
Thread Closed
Tags
charges, coulomb's law, direction, epsilon, magnitude
Thread Tools
Similar Threads for: Force exerted by two charges
Thread Forum Replies
Exerted force 40N and 40N? Introductory Physics Homework 1
Exerted force? Introductory Physics Homework 1
Magnitude of Forces exerted by charges. Introductory Physics Homework 5
Net force exerted by two charges on a 3rd charge Introductory Physics Homework 1
Force exerted? Introductory Physics Homework 3
